Thread: change engine to diesel
    nottingham
    Default change engine to diesel
    hi. i need to change my 1.8 petral engine as a snapped cambelt ******ed the valves and was wondering if i could drop in a diesel ingine instead with not much difficulty. i know a new tank would be needed as well as fuel leads but dont know what else . if anyone does and can fill me in it'd be much appreciated. cheers
    Full Member Penfold101's Avatar
    Just get a new car mate, the engines are far too complicated and dependant on computers to make this even a possibility I'd have thought...
    Bristol
    Vehicle : CDTI 150
    Agree with penfold, either like for like engine or new car.
    Few other things to consider
    Due to the additional weight of an oil-burner youi would need to upgrade the front suspension and possibly the brakes.
    Then there is the circuitry for the glow plugs different wiring for the Tacho (diesels timed off alternator not coil)
    as well as the need for the entire front looms to be changed, a massive session on swapping in the new ecu's and tech2ing the car to really confuse it.
    it's really not going to make massive sense, and will cost you far more than you hope to save by running the diesel..as well as the new diesel lump costing more than the petrol one..
    If it's just the cambelt snapped. you would be VERY unlucky to have seriously damaged the pistons and normally a new/salvage/recon cylinder head is all thats needed..parts would be around £400...
  1. astra diesel alternator change
    By tyler boy in forum General Motoring Chat
    Last Post: 8th November 2011, 16:46
  2. V6 3.0 diesel 2005 Belt change mileage
    By NPS in forum Engine & Drivetrain
    Last Post: 10th April 2011, 16:48
  3. diesel oil change
    By darlo123 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 21:24
  4. diesel filter change
    Last Post: 15th June 2010, 23:40
  5. Which diesel engine??
    By cornishtaz in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 17:39
