Thread: Is my gear box F****
    newark
    Default Is my gear box F****
    Hi my automatic box has lost its reverse drive it will go forward and change gear as it should, no revers also when in neutral it seems to be in park ie you can not push it forward or backwards, Is it only the gear box failure can cause this or some thing else ie ecu or linkage please help as just about to order reconditioned unit i woul hate to find after it was soe thing simple.
    it should roll in neutral. So it does point to the gearbox being in need of replacement.the linkage is just a cable and doesn't physically control anything as the box is electronic.
    Feb 2006
    Guttedsville
    You haven't dropped 10p down the gate or something have you?
    Quote Originally Posted by AndrewTi View Post
    just because it happened to me..:..
    worth a look though if you do leave change in the ashtray..
    Feb 2006
    Guttedsville
    newark
    Default ur maybe worth a look
    hi gear shift moves into positon could there still be some thing down the gator ur forgot to mention when in reverse you can here strain on engine but car dont move
    Regular Member sri22dti's Avatar
    Northern Ireland
    Is this vectra a 2001 vectra b
    newark
    Hi yes model
    16v cd 2001
    Preston Area
    don't go there... mine was a quid
    Quote Originally Posted by sri22dti View Post
    similar 'family' of boxes to the 'C'.....
    can you rotate one wheel freely wheel the car is raised.. i.e. is it a problem with the differential?..if not then it does really point to the box
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
