Results 1 to 10 of 19
Thread: Air box mod?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Default Air box mod?
    Hi all just a quickie have noticed alot of folks speaking about air box mods what exactley is the mod?and does it work on the CDTIs 150 thanks in advance for your help
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    The mod is removing the bottom inlet section of the airbox as currently you are only using half of the air filter - most will do this in conjunction with fitting a K&N filter (or similar) - simple mod that will take 10 mins max!!
    Aberdeenshire
    Ok cheers bud il have a look tommorow is it worth doing with the standard filter in place?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Yep, definately worth doing.
    You won't notice a massive difference but it's free so you might aswell.
    Feb 2007
    The pool
    you might but you would notice the difference with K&N!!
    Aberdeenshire
    Cheers lads is there a how to guide on the forum or is it really that simple?
    Feb 2007
    The pool
    Its really that simple!!
    Aberdeenshire
    cool thanks for the info guys il get it done tommoz.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Look HERE mate.
    Aberdeenshire
    Cheers mate very helpful can i also ask where you got your k&n from and how much was it?
