Results 1 to 10 of 11
Thread: drilled and grooved brake discs
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    Default drilled and grooved brake discs
    has anybody on here found a suppiler of drilled and grooved discs as my originals are now quite worn down and was thinking of changing to this type as i did with the vec "b"
    North east HQ
    you could always do what drinky did and groove and crossdrill your own discs - works out a lot cheaper LOL
    Nov 2005
    Stotfold
    Default Brake Discs
    I would personally just go for groved discs with plenty of grooves, my mate races cars and said the problem with drilled discs is that you get radial distortion and this can cause a bit of judder, also look at race cars you dont see many with drilled discs they are just usually grooved, so i would reccommend just grooved, they are also a lot cheaper unless you want to show off!
    thanks chaps has anyone seen these for sale anywhere?
    I have had a good look for them with no luck I`m afraid. Another option is a GSi upgrade which is available through LMF with a club discount, or wait to see if the vxR jobs will fit ??
    VXR discs are a massive 345mm so i'd wait for them. Plus you could always do a 'Drinky' and drill the holes yourself. ;-)
    Quote Originally Posted by armoured farmer
    There's no rear discs listed. Odd!
    SCOTLAND
    you can get rossini grooved discs for the veccy c as reccommended in total vauxhall a month or so ago. i'll look up the uk supplier tomorrow evening and post up.
    Quote Originally Posted by Graeme
    cheers mate
  1. Drilled and grooved discs
    By sla002 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 20:27
  2. Cheap grooved and drilled/dimpled discs
    By Ben Chiles in forum Tuning
    Last Post: 24th February 2011, 16:44
  3. Drilled and grooved front discs
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2010, 20:53
  4. Drilled and grooved front+rear discs
    By mucklestone in forum Handling & Braking
    Last Post: 17th August 2009, 19:59
  5. Can i get Front Drilled and Grooved Discs
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2006, 14:41
