Thread: Tyre pressure
    Regular Member EARLEY's Avatar
    Oct 2007
    Liverpool
    Default Tyre pressure
    What is the correct tyre pressure for a 2006 SRI 150 with 17" wheels and standard Goodyear Eagle NCT 5 215 50 17 ??
    Thanks lads and lasses
    Regular Member DeathStar's Avatar
    UP North
    Have a shufty at the attached
    Oct 2007
    Liverpool
    Just checked my fronts there on 40 rears are on 30 what should i put them at will i have problems with these? if i dont sort it out asap
    UP North
    You will get increased wear at the higher pressures in the centre. With the lower pressures will get increased wear at the edges.
    Also with the higher pressures you will get a bit of instability.
    I would set them as per the recommendation
    Jul 2006
    is it 36 front 32 rear? can't remember....
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. Tyre pressure
    By Ralphwells1967 in forum Handling & Braking
    Last Post: 8th May 2010, 19:26
  3. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  4. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  5. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
