Thread: Fog light misted up!
    N E Somerset
    Default Fog light misted up!
    Anyone know if this is a common problem? One side ok but the other seems to be permanently full of condensation. Presume if it's a fault, it would be replaced under warranty/ or Network Q?
    good side
    bad side
    Regular Member silverhairedracer's Avatar
    ESSEX
    I had this problem with my vec B,so as not to impare the lens I used the wifes hair dryer to dry it out,she was out at the time,then put some vasaline on the seals,cured the problem.
    Regular Member Grizzly's Avatar
    May 2007
    Scotland
    Have the same problem myself, there are a lot of posts about this issue on the forum. It is something to do with the fact the water bottle sits above this fog lamp.
    From what I understand is if you turn your fog lamps on and it clear within 20 minutes the garage will not consider it to be faulty.
    Just noticed today I am getting a lot of conisation in my main headlight casings as well (On both sides) which is a little more worrying
    N E Somerset
    thanks for that. i'm not familiar with these at all, how do you remove them to work on and what seal?
    N E Somerset
    yea, i've had small amounts of misting up in one of my headlamps a while ago but it cleared itself, not nice to look at and as you say, a bit worrying.
    11 Post(s)
    Quote Originally Posted by Grizzly View Post
    I ended up taking mine off, drying thoroughly with a hair drier, and it's not misted up since.
    Couldn't for the life of me figure out how the water got in (when I took the bottom cover off approx an egg cup full draind out). I even submerged it in a bucket of water for 10 mins and no water got in. Perhaps whatever seal was leaking beforehand, stopped after I had taken what I could apart.
    Mileage : 000
    Over filling the washer bottle, is a good cause of it.
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Had my nearside foglight replaced under warranty last week.
    This a common problem, I just told them that despite having used the lamp reguarly with the recent bad weather it was still misted up, he said 'well it is a fog lamp'...(no he didnt I'm being ironic!)
    They changed it for a nice new one!
    i've got packets of silica gel in mine to keep them dry.. works well..
    Sunny Dartmoor
    What a great idea......
  1. misted up headlight
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 22:03
  2. Misted Lights
    Last Post: 30th November 2009, 22:20
  3. headlight misted up
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2009, 15:01
  4. misted windows
    By pyro_maniac in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 14:21
  5. Fog light misted up
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2007, 23:01
