Thread: problems with wipers
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    Default problems with wipers
    anybody ever had problems with their wipers .mine stopped working yesterday took to vaux .put on new wiper motor came home still keeps stopping every now and then HELP PLEASE
    Regular Member benny's Avatar
    Feb 2006
    dudley
    do you have it set on rain sensative setting (if you have it fitted?(
    May 2007
    manchester
    Hi Mate No Not Got It Fitted Does 2-3 Wipes Ok Then Starts To Slow Down
    Regular Member dazzer t's Avatar
    stoke on trent
    hi mate had the same problem with mine you will have to take it to your local dealer( if its still under warranty) i think it is a fault with the wiper control module, it only took them about 15 mins to sort mine out.
    Cirencester
    on the rear?
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    I've had 2 replaced in less than a year.
    Seems to be a common fault, as water drips onto the wiper motor plug and shorts it out.
    If I were you I'd just take it back and get another one.
    Feb 2006
    dudley
    sounds like high resistance water getting into a plug or control unit some where
    May 2007
    manchester
    cheers guys its booked back in for tuesday .when they put the new motor on it kept blowing the fuse on the top speed so they want it back to check it .but it stopped again yesterday at least i know its not just mine
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. new wipers
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2006, 10:40
