Results 1 to 10 of 15
Thread: coolant
    Regular Member Grizzly's Avatar
    May 2007
    Scotland
    Default coolant
    Really blonde question for the petrol heads, Having had a company car most of my life any issues it went straight into the garage. I now own a Ventra 06 the coolant low warning light has just come on, checking the bottle the level is about an inch away from the line (Below).
    Is it as simple as popping to Halfords and buying anti-freeze (Orange stuff) and topping it up? Also noticed Halfords do a large range is there any in particular you would recommend
    Grizzly
    member of the smoke patrol 230bhp+
    just top it up with a bit of water
    May 2007
    Scotland
    Cool, Cheers for the reply
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    If you want to top up with antifreeze then you need to use VX longlife which would have been used in the factory.......any other kind won't mix and it turns to a kind of jelly...only about a quid + vat for a litre at the stealers
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Second that advice. Antifreeze these days doesn't seem to be interchangeable - you need the red GM stuff from main dealers. It's not expensive
    Regular Member crucial's Avatar
    Oct 2007
    kent
    when they changed the oil cooler on my 3.2 they drained all the coolant and replaced it with the blue stuff. Is this ok to do? Any ill side effects?
    you will just need to replace it every 3 years max...the Blue is 'old' style formulation and breaks down more quickly...RED is 'longlife' and stays more 'stable' for 5 years...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, like we all do that
    am i the only one.....
    lol, nope - I've just done mine. I was going to replace it anyway before winter, but the removal of the turbo kinda forced me into doing it sooner anyway as I had to drain the coolant to remove it.
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
