Thread: Which Oil
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Which Oil
    The light has came on to tell me that the car needs oil but which one, also is it best to put the oil in when t to car is cold or warm
    Thanks Steve
    1.9 cdti sxi
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    I like to use at least a semi synthetic oil. I would say with oil, you pay for what you get.
    The oil will need to be warm if you are changing it and replacing the filter as it reduces the viscosity and runs out better.
    If your just topping up what is already in there, then it doesnt really matter if its warm or cold.
    Quote Originally Posted by sonicboom View Post
    Thanks M8 just topping it up
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    We use 5w 30 fully sunthetic oil in all Vectra C's at work.
    I have some castrol gtx magnatec 10W-40 for all modern engines (synthetic ) would this be ok?
    Steve
    Jun 2006
    Northampton
    Quote Originally Posted by vectra 120 View Post
    Steve
    I wouldn't recommend mixing oils IMO.
