Results 1 to 8 of 8
Thread: Rear Wiper Not Working
    Regular Member djr69uk's Avatar
    Feb 2008
    Midlands
    Default Rear Wiper Not Working
    My rear wiper doesn't work. I first tried swapping the 15A fuse but that didn't work. The wiper stalk makes the popping noise when you cancel the rear wipe, so I don't think it's the stalk. So I bought a replacement wiper motor off Ebay. I attached the connector to the new motor and it still doesn't work!
    So if it isn't the motor, isn't the fuse, isn't the stalk... what do I check next? Is there a relay or something somewhere that I can check? Everything else appears to work fine.
    Technical directors office
    diagnostic machine time....sounds like a CIM module problem
    Feb 2008
    Midlands
    just out of warranty mate.
    anything else i can check myself?
    only if you can probe the plug out for a 12v signal... apart from that not much you can do without a machine that will read body codes..
    Feb 2008
    Midlands
    i've got a 'donor' Veccie facelift sitting outside at the moment. anything i can try swapping over to see what the cause might be? what it the CIM module? is there a relay I can swap over to test?
    Full Member Steel's Avatar
    Feb 2008
    Sheffield
    Trim : SRI CDTI NAV
    Engine : Z19DTH
    Mileage : 258,000
    Forgive me for being confused but how can it be out of warranty if its a facelift? Mine is pre facelift and is still under warranty (not much of it left now though lol)
    Despite the cost of living it still seems popular!
    Feb 2008
    Midlands
    3 year or 60k miles mate...
    Feb 2008
    Midlands
    the dealer nailed this one for me yesterday. turned out to be a simple relay problem. with diagnostics, supply and fit... £65!
  1. rear wiper not working?
    By crinks85 in forum Bodywork & Interior
    Last Post: 5th March 2012, 21:18
  2. Rear wiper not working
    By Vectra- in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 20:13
  3. Rear Wiper not working. help
    By Ayrcomm in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:01
  4. Rear wiper stopped working!!
    By marwen in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 21:29
  5. wiper not working???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 18:10
