here is some details of whats offer if anyone is interested, it seems as though most things are covered but one question ill be asking is are diagnostics also included?
www.warrantydirect.co.uk
Engine
Cylinder head, internal bushings, oil pump,
crankshaft and bearings, tappet gear, valves and
guides (excluding burnt or pitted valves), pistons
and rings, cylinder bores/liners, con rods,
distributor drive, starter ring gear, flywheel,
autodrive plate, camshaft drive belts, camshaft
and cam followers, cylinder head gasket,
turbo/intercooler units, rocker assembly; push
rods; timing gears; timing belts
and chains
Clutch
Master and slave cylinder, clutch cable and pedal
assembly.
Transmission
(Manual, Automatic and Overdrive)
Manual Transmission: gears, synchromesh hubs &
rings, selectors, shafts, bearings, drive chains plus
gearlever and bushes.
Automatic Transmission: torque converters, brake
bands, valve block, governor (manual & electric)
oil pump and seals, drive chains, gears, input shaft
oil seal, clutches, servos and modulator valve,
bearings plus gearlever and bushes. Overdrive:
Gears, shafts and bearings.
Front Wheel Drive Unit
Crown wheel and pinion bushes and bearings,
plus external drive shafts, universal joints and
couplings, C.V. joints and differential unit.
Rear Axle
Crown wheel and pinion, shafts, bearings, C.V.
Propshaft
Propshaft, universal joints and centre bearings.
Four Wheel Drive System
Shafts and bearings , plus propshaft, couplings,
C.V. joints, front differential: interaxle differential
and lock; rear differential and lock.
Braking System
Master cylinder; brake servo unit, callipers, wheel
cylinders, pressure reducing and proportioning
valves, ABS pump and control unit
Cooling System
Radiator, thermostat, water pump, heater matrix,
viscous fan, thermostat housing.
Steering
Rack and pinion, steering box, idler box, column
shaft, couplings, power steering unit including
pump, pressure pipes and reservoir, tie rods and
tie rod ends.
Fuel System
Mechanical and electrical fuel pumps, airflow
meter, fuel distributor, warm-up regulator, cold
start injector, fuel gauge and tank sender unit.
Diesel Injection System
D.I.S. pump and injectors.
Electronic Ignition
Ignition ECU and Ignition Coils where fitted as
standard by the manufacturer.
Electrics
Internal failure of the starter motor, alternator,
voltage regulator, distributor, windscreen wiper
motor, horn, electric window motors and front
and rear windscreen washer motors, indicator
flasher unit, heating fan motors and cooling fan
motor.
Bodywork
Tailgate suspension struts
Casings
Casings are covered provided they have been
damaged as a result of failure of an insured part
or by the consequential damage of an insured
part failing.
Only the components originally fitted as standard
by the manufacturer are covered unless agreed in
writing by us.
Fuel System
Air Fuel Ratio Sensor
Air Induction System
Air Pump
Anti-Knock Sensor
Barometric Pressure Sensor
Canister Purge Solenoid
Deceleration Valve
EGR Recirculation System
EGR/EFE Thermal Vacuum Switch
EGR/EFE Valve
Fuel Receptacle
Fuel Sensor
Fuel Tank Pressure Control Valve (PCV)
Fuel Temperature Sensor
Idle Air Control Valve
Intake Air Resonator
Intake Air Temperature Sensor
Manifold Air Pressure (MAP) Sensor
Mass Air Flow Sensor
Oil/Air Separator
Oxygen Sensor
PCV System
Powertrain Control Module (PCM)
Secondary Air Injection System
Throttle Body Assembly (MFI)
Fuel Tank
Fuel Fill Pipe and Cap
Fuel Fill Neck Restrictor
Engine
Engine Oil Fill Cap
Intake Manifold
Positive Crankcase Ventilation Valve
Airbag Cover
We will cover the following:-
Airbag Cable/Contact Coil
Clock Spring
Airbag Sensor(s) including occupancy sensors
Airbag Module (ECU)
On/Off switch
However, we won’t cover the airbag itself as
failure is quite rare, and if the bag fails to deploy
or has been deployed, this is normally covered
under manufacturer’s warranty or your car
insurance policy.
writing by
