Thread: none dealer warranty yes or no ?
    Regular Member STAV's Avatar
    Oct 2006
    tyne & wear hebburn
    Default none dealer warranty yes or no ?
    ive been considering a warranty for my signum which has 74k on the clock and after reading hoards of info ive got a quote from warranty direct for £275, the thing is are these warrantys actually worth the paper there written on? anyone had or taken one out with these guys or anyone else and had a happy outcome when something went wrong or has it been a total waist of money?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    just paid £399.00 for a network Q one for our motor, looked at all the other's avliable inc these and one from the AA for £65.00 per year (covers first £500.00 part's and labour) decided better the devil you know in the end
    Midlands Mod Shop - NFFC.
    Regular Member Islander's Avatar
    Barrow-in-Furness
    I had one for a Subaru I once owned ( can't remember which company ) i.m.o.
    it was'nt worth the paper it was written on!!!!!
    I had one on my previous Mondeo, and even paid for the TOTAL package
    The EGR turbo pipe failed, claim declined as the part wasn't covered
    One exhaust valve snapped and ended up in the turbo
    A full engine rebuild was required, but they only paid for the failed part and associated labour, thankfully though Ford came to my assistance as it happened three weeks before the cars first MoT, even though it was 45K miles out of Ford warranty!
    The tyre cover was very good, I used up five of the six permitted claims, all fully paid at £150 per tyre
    The "Vauxhall / Sureguard / Vauxhall Retalier Guarantees" warranties are the best I have found for high mileage drivers, hence why I am back with Vauxhall
    I dumped the original warranty, Network Q warranty, and opted for the Vauxhall Complete Protection Plan instead!
    Oct 2006
    tyne & wear hebburn
    here is some details of whats offer if anyone is interested, it seems as though most things are covered but one question ill be asking is are diagnostics also included?
    www.warrantydirect.co.uk
    Engine
    Cylinder head, internal bushings, oil pump,
    crankshaft and bearings, tappet gear, valves and
    guides (excluding burnt or pitted valves), pistons
    and rings, cylinder bores/liners, con rods,
    distributor drive, starter ring gear, flywheel,
    autodrive plate, camshaft drive belts, camshaft
    and cam followers, cylinder head gasket,
    turbo/intercooler units, rocker assembly; push
    rods; timing gears; timing belts
    and chains
    Clutch
    Master and slave cylinder, clutch cable and pedal
    assembly.
    Transmission
    (Manual, Automatic and Overdrive)
    Manual Transmission: gears, synchromesh hubs &
    rings, selectors, shafts, bearings, drive chains plus
    gearlever and bushes.
    Automatic Transmission: torque converters, brake
    bands, valve block, governor (manual & electric)
    oil pump and seals, drive chains, gears, input shaft
    oil seal, clutches, servos and modulator valve,
    bearings plus gearlever and bushes. Overdrive:
    Gears, shafts and bearings.
    Front Wheel Drive Unit
    Crown wheel and pinion bushes and bearings,
    plus external drive shafts, universal joints and
    couplings, C.V. joints and differential unit.
    Rear Axle
    Crown wheel and pinion, shafts, bearings, C.V.
    Propshaft
    Propshaft, universal joints and centre bearings.
    Four Wheel Drive System
    Shafts and bearings , plus propshaft, couplings,
    C.V. joints, front differential: interaxle differential
    and lock; rear differential and lock.
    Braking System
    Master cylinder; brake servo unit, callipers, wheel
    cylinders, pressure reducing and proportioning
    valves, ABS pump and control unit
    Cooling System
    Radiator, thermostat, water pump, heater matrix,
    viscous fan, thermostat housing.
    Steering
    Rack and pinion, steering box, idler box, column
    shaft, couplings, power steering unit including
    pump, pressure pipes and reservoir, tie rods and
    tie rod ends.
    Fuel System
    Mechanical and electrical fuel pumps, airflow
    meter, fuel distributor, warm-up regulator, cold
    start injector, fuel gauge and tank sender unit.
    Diesel Injection System
    D.I.S. pump and injectors.
    Electronic Ignition
    Ignition ECU and Ignition Coils where fitted as
    standard by the manufacturer.
    Electrics
    Internal failure of the starter motor, alternator,
    voltage regulator, distributor, windscreen wiper
    motor, horn, electric window motors and front
    and rear windscreen washer motors, indicator
    flasher unit, heating fan motors and cooling fan
    motor.
    Bodywork
    Tailgate suspension struts
    Casings
    Casings are covered provided they have been
    damaged as a result of failure of an insured part
    or by the consequential damage of an insured
    part failing.
    Only the components originally fitted as standard
    by the manufacturer are covered unless agreed in
    writing by us.
    Fuel System
    Air Fuel Ratio Sensor
    Air Induction System
    Air Pump
    Anti-Knock Sensor
    Barometric Pressure Sensor
    Canister Purge Solenoid
    Deceleration Valve
    EGR Recirculation System
    EGR/EFE Thermal Vacuum Switch
    EGR/EFE Valve
    Fuel Receptacle
    Fuel Sensor
    Fuel Tank Pressure Control Valve (PCV)
    Fuel Temperature Sensor
    Idle Air Control Valve
    Intake Air Resonator
    Intake Air Temperature Sensor
    Manifold Air Pressure (MAP) Sensor
    Mass Air Flow Sensor
    Oil/Air Separator
    Oxygen Sensor
    PCV System
    Powertrain Control Module (PCM)
    Secondary Air Injection System
    Throttle Body Assembly (MFI)
    Fuel Tank
    Fuel Fill Pipe and Cap
    Fuel Fill Neck Restrictor
    Engine
    Engine Oil Fill Cap
    Intake Manifold
    Positive Crankcase Ventilation Valve
    Airbag Cover
    We will cover the following:-
    Airbag Cable/Contact Coil
    Clock Spring
    Airbag Sensor(s) including occupancy sensors
    Airbag Module (ECU)
    On/Off switch
    However, we won’t cover the airbag itself as
    failure is quite rare, and if the bag fails to deploy
    or has been deployed, this is normally covered
    under manufacturer’s warranty or your car
    insurance policy.
    writing by
    Diagnostics are NOT covered
    That policy also doesn't cover the EGR pipe on the turbo (if you have a diesel)
    Note that they ONLY pay for the component failure and the labour associated to that part
    So if the head gasket fails, they only pay for the labour to get to that part, replace it, and refit
    That's about 30%, the rest you need to pay for!
    Oct 2006
    tyne & wear hebburn
    cheers mate ,nope ive a 2.0t petrol but i just dont want to had over nearly 300 notes for never to hear from them again and if something does go wrong for some snotty rep telling me that im not covered, ( all queries should be face to face imo )
    member of the smoke patrol 230bhp+
    network Q
    warranty direct are $hit i know iv got one
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Alot of times they will say its wear and tear and they wont pay out
    Oct 2006
    tyne & wear hebburn
    good point mate, so ive just checked wear and tear and as my car has over 70000 miles they pay 100% labour and 90% parts
  1. 3 month warranty but only if I take it back to the dealer I bought from.
    By bennettboy in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 15:44
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. new member + help needed with 1st fault while car still under dealer warranty
    By remifromnottingham in forum Engine & Drivetrain
    Last Post: 5th July 2011, 21:18
  4. sevice at non VX dealer to keep warranty valid
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2007, 10:22
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
