Thread: U581 Fault Code Scanner
    Regular Member robzc's Avatar
    Mar 2007
    South West
    Question U581 Fault Code Scanner
    U581 OBDII Scanner - Anyone else got one of these? I received mine today, it works great telling me what RPM the motor is running at, speed, air flows, temps, except it constantly reads No Trouble Codes, even though my spanner light is on.
    The trouble code reset works, spanner light goes out, but comes back on next restart. I've tried rescanning, everything, just doesn't pick up any fault codes, even when the spanner light is on.
    According to the manual, the MIL indicator is the fault lamp as I know it, and even when this lamp is on, the scanner shows MIL off.
    Any ideas?
    ADD: Car is a Vectra Estate, 2004 1.9 CDTi (120)
    Feb 2007
    Glasgow
    You're only scanning the ECM, which in this case, has no fault codes logged.
    The 'spanner light' isn't the MIL indicator, the MIL indicator is in the bottom right hand corner of the dash.
    There's a number of modules that can log faults that the U581 isn't capable of scanning... ABS, EHPS, etc. If one of them has a fault logged, then the spanner light will come on, but you won't be able to find out which one it is with the U581.
    Hope that makes sense.
    Mar 2007
    South West
    Makes sense - I have a £80 paperweight... so I'll have to pay the Stealers in Bristol £65 for the honour of telling me what my fault is. Any scanners on the market that read these codes, or is it just the hi level software / laptop units that do this?
    Feb 2007
    Glasgow
    I don't think there's any of the low cost scanners that can read anything other than engine codes. The U581 is still quite handy though.
    Looks like a trip to the stealers
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Try googling for a canbus scanner, I've seen some units online somewhere that scan all the systems the same as the tech 2 does..
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Found this one that does the complete car and supports canbus.. 799 euros though.. when im signed back to work i may think about getting one of these... And hire it out.....!
    http://www.auto-diagnostics.info/opel_diagnostics
    it does Vec-c & signums from 2002 upto 2007..
    http://www.auto-diagnostics.info/ecu...ctra_c_signum/
    http://www.auto-diagnostics.info/scr.../en/opeldiag/5
    member of the smoke patrol 230bhp+
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by chrisgettings View Post
    Hi Chris...
    I think My sister has got me one of those as part of my chrimbo pressie from the same place...
    Quote Originally Posted by Big-Pete View Post
    Hi Chris...
    you can tell me if it any good then
    it looks to do a lot, we might be lucky and be able to pull 0 to 60 times out of it to
    Feb 2007
    Glasgow
    That's the U581, same one as robzc was asking about, it is good but it will only scan the ECM and show some live data.
    Vaux-com will scan everything, do actuator tests and do some programming too, but costs £500.
    That auto-diagnostics one looks quite neat, though
  1. U480 Fault Code Scanner
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 13:48
  2. Car Diagnostic Code Reader / Scanner OBD2 CAN U581 2009
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
  3. Vectra 1.9cdti (150) and using U581 code reader
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 17:28
  4. OBD 11 fault scanner.
    By Hoffmeister in forum Engine & Drivetrain
    Last Post: 24th October 2008, 13:30
  5. OBD 2 can bus code scanner
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2008, 22:37
