Results 1 to 10 of 23
Thread: CRD2 Problems
    Nov 2007
    aylesbury
    Default CRD2 Problems
    Chaps, not sure whether this should be in here or under problems?
    Bought the CRD2 for 3ltr v6 cdti siggy on a 53 plate from a very helpful gent on here. Fitted it weds and done about 200 miles or so but on the way home the engine died, management light came on and travelled the last 40 miles of my commute in limp mode. Its set on -1 as I have been gradually increasing it as I have read it is advised.
    It was a little 'lumpy' driving it home but sort of cleared when the revs were up.
    Any ideas?
    Also if I can get this resolved then would appreciate an understanding of the jumper settings!
    SB
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    Sounds like my problems http://forum.vectra-c.com/showthread.php?t=34357, see link
    Nov 2007
    aylesbury
    did you ever resolve your issues then Rob, doesnt appear so reading your thread?
    Oct 2007
    All I can say is its better and on Program 2+2 It seems ok!!
    Oct 2007
    SPOKE TOO SOON, CUT OUT INTO LIMP MODE TODAY!!!!! i GET THE FEELING IT IS NOT SAFE!!!
    Nov 2007
    aylesbury
    I dunno whether I'll bother putting mine back on, typical sounds like a waste of 140 quid!!
    Will scout the other forums to see if I can find alternate solution if not fleabay me thinks
    EVERYWHERE
    I've been running mine for quite some time now on the -3 setting on my CRD box.The car does quite a lot of urban work,but neither I nor my Wife hang about on the open road.The V6 seems particularly sensitive to excess emissions and also high and low fuel pressure.The ECU doesn't like to be mucked around with,which is why I've left mine on -3.
    Nov 2007
    aylesbury
    hi diesel dog, what map setting are you are currently running so i can try that before i decide to sell it
    Oct 2007
    Good Call
    EVERYWHERE
    Quote Originally Posted by SausageBoy View Post
    Being a CRD box it only has a single map.But as with all digital boxes the map can be altered or completely replaced.I sent the box off to dragonperformance and they downloaded a much better map onto the box than the original Powerklick map.They described it as their "most popular" map.
    You can send your box to them and they will replace one or all the maps for a small fee.
    I have had no problems with this map on my car and I find that there is no noticeable advantage in running with the box above the minimum setting.I would suggest that you use the least powerful map on the lowest voltage setting and see what happens.
  1. difference between a DTUK CRD2 (09) & CRD2 Multi-Map®?
    By Beckman in forum Diesel Engine related
    Last Post: 10th December 2010, 22:49
  2. Crd2
    By mattlank6 in forum Diesel Engine related
    Last Post: 17th February 2009, 15:51
  3. which map are you using on the crd2?
    By philipsmith in forum Diesel Engine related
    Last Post: 2nd February 2008, 09:57
  4. CRD2 box
    By willc01 in forum Diesel Engine related
    Last Post: 12th December 2006, 23:10
