Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 314mm upgrade...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default 314mm upgrade...
    Just curious to know what the going rate is these days for a 314mm brake upgrade to include calipers, discs, pads etc I think LMF was just over £400, just wanna make sure I've not paid too much for mine.
    Here, there and every where!
    http://www.lmfvauxhall.co.uk/store/p...2&cat=0&page=1
    £319 from LMF m8. Have a word with Steve as i paid a lot less than that when he was doing a "special" for the forum
    Jun 2006
    Northampton
    Quote Originally Posted by Caterman View Post
    My one I've done is costing me £250 so thats not too bad then compared to that.
    Tyneside
    What is actually needed, I know calipers, discs and pads, but is it different brackets as well?
    Jun 2006
    Northampton
    Quote Originally Posted by mark1319 View Post
    I've ordered up the brackets, the calipers, and the discs and pads, thats all I could see was needed in the pic on EPC.
    No m8, just the calipers, discs and pads The carriers are the same. You might need 4 new bolts though. I broke one of mine getting it off so changed the lot They are less than £2 each.
    Jun 2006
    Northampton
    Hmm well if the carriers aren't needed that drops the price down to £160
    That is cheap
    When i did mine, all i did was undo the 2 torx bolts holding the caliper on and fitted the new caliper. You should also fit a new washer to the banjo bolt on the brake hose though.
    Jun 2006
    Northampton
    That is cheap
    I was gonna get all new fixings etc while I was at it, is it worth going for braided hoses at all??
    Tyneside
    ****** hell thats basically half price your getting. This is definetelly on my list of things to get.
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. 314mm Upgrade
    By AdeyCorp in forum Handling & Braking
    Last Post: 28th June 2009, 08:10
  3. GSi Brake upgrade to 314mm?
    By fuzzbomUK in forum Handling & Braking
    Last Post: 16th September 2008, 12:57
  4. Help please. 314mm upgrade
    By Vec-trance in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2008, 02:08
