Thread: nearly out of warranty
    Aug 2007
    Rugby, warwickshire
    Default nearly out of warranty
    hi guys, just wondered if you had any ideas on the following:
    My car is a 2005 Vectra SRi 2.2. nav DIRECT. I braught it from a used car dealer in 2006 at 10 months old. It was registered March 2005.
    I have several problems with the car:
    1) Fog lights get condensation in them.
    2) left mirros control adjusts left mirror, right setting adjusts BOTH mirrors.
    3) Album change / cd/radio buttons on wheel get mixed up some times ( sports wheel / cd70 navi )
    4) next track button will sometimes go BACk a track.
    and the car has just started to make really unerving metal on metal BANG noise from rear suspension ( no regular / intermittent )
    In your opinion, where will i stand with these issues and my local vauxhall dealer REF warrenty.
    Many thanks
    Karlos
    Regular Member Karl's Avatar
    Sunderland
    Quote Originally Posted by karlos007 View Post
    believe it or not, its meant to. It means (apparently) if you are dropping the mirrors for reversing then both do the same. Personally I think its a stupid idea but hey ho.....
    The stereo controls sound like a dodgy connector, I would have them checked by the dealer.
    Condensation in the fog lights is purely down to badly sealed units, hard to claim on under warranty as all you will get is that it is due to stone chipping etc....
    best of luck
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    When I took my bumper off I just took the backing off the fog and turned them on for half an hour then resealed them tightly. Never fogged up since.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Karl View Post
    It's not so much for that - reversing - its so that once you've set them up you then just push the rocker switch left or right, if you move the seat, and the mirrors will both move in our out at the same time.
    Karlos - what you do is push in the right button and adjust the driver mirror to where you want it, ignore what the passenger mirror is doing. Then push in the left button and adjust the passenger mirror to suit. Now push in the right button. From now on if you move the seat, you will be able to push either the left or right rocker switch and the mirrors will move together to the right adjustment. That's the theory, and once you're used to it's actually not so bad.
    Aug 2007
    Rugby, warwickshire
    cheers guys!!!
    It actually makes perfect sense now ( mirrors ), and is pretty much how i was getting round it!
    My biggest concern is the suspension - will they sting me like a beeatch for it or will the warrenty cover it?
    Thanks Again
    Karlos
    Have you looked at the rear springs to make sure one hasn't broken? Does the back end feel very wallowy? Give the back end a bounce test to see if it all settles quickly. The Vectra C is known to eat rear shocks, so they may say it's wear and tear. If it's a broken spring then that should definitely be under warranty.
    Either way, get them to give the rear suspension a good looking over as most problems they may uncover should be covered.
    Aug 2007
    Rugby, warwickshire
    cheers, am taking her in on monday i think. one thing i did notice, is on the mondeos i had, the shock and coil was always running vertically behind the wheel up into some susp[ension turrets in the boot, yet i cant see anytyhing behined the rear wheels on vectra.
    Do the vectras have a radically diffrent set up?
    Karlos
  1. Do I get a warranty??
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 13:00
  2. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  3. Warranty
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 22:04
  4. warranty
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 21:13
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
does vectra c eats rear shocks quicker
