Thread: Engine Problems again Spanner and juddering !
    Regular Member CdRsKuLL's Avatar
    Aug 2007
    Bolton
    Eek Engine Problems again Spanner and juddering !
    My orange spanner keeps flashing on and off and the car feels like its miss firing very badly.. but it cant be because its a diesel 1.9 cdti.. hmm I got my little CAN reader and plugged it in and it said..
    P0302.. Circuit Open 3 cylinder injector
    Any help on this one guys ? I'm assuming its a fault with one of my injectors... or maybe the sensor ? Is this common and can I maybe swap stuff round to double check.. ie swap injector 2 and 3 about and see if the code shifts over ?
    o.. yeah and which end do you count the cylinders from ?
    thanks and keeping my fingers x'd someone can help me.
    Steve
    Nov 2005
    scotland
    how old is your car ?
    there is a field remedy for early 1.9's where you change the multi plugs on the injectors.
    the injectors are coded to each cylinder by the way
    Aug 2007
    Bolton
    sorry m8, missed your post..
    Car 04 1.9 cdti Design 150 - 51k
    well after having a little more time and doing a bit of reading.. I have just come back in from looking at my car.. O.. I should of guessed really
    Yet another 1.9 cdti 150 fault !!!!
    pic's here...
    It appears its the swirl control rod (effects torque at low rev's). As I've always thought the car was gutless at low revs I'm presuming this was always faulty.. even when I bought the car.. Also I'm guessing one of the connections is at fault as well.
    So what now.. I'm thinking get it in VX for a quote and also contact VX customer service about this 'known' fault and also send watchdog a letter explaining that I'm not alone !
    anyone care to add there name to the list ?
    Steve
    Aug 2007
    Bolton
    Just thought I would post a fix it.. well a temp one anyway..
    repect goes to the poster :-)
    http://forum.vectra-c.com/showthread...highlight=pete
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Juddering problems - im stuck
    By paulcoates in forum Engine & Drivetrain
    Last Post: 30th January 2012, 18:00
  3. 1.9 CDTi 150, juddering and spanner!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 19th May 2009, 15:57
  4. Car juddering / limping along... Spanner light also coming on.
    By zim_zimmer in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2008, 19:00
  5. Juddering and intermittent spanner light
    By matth42 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2008, 01:53
