Results 1 to 3 of 3
Thread: 2.0 Turbo - Juddering
    Nov 2007
    Salisbury
    Default 2.0 Turbo - Juddering
    Howdie Folks,
    I have been reading about the judder which seems to be a common problem with the 1.8 Vectra.
    I seem to have the same sort of problem with my 2.0 Turbo. From cold (and damp days) when coming to a stop at a juction there is a distinctive judder coming from the front end which i can only assume is the clutch.
    Has anyone else with a 2.0T had this problem, or can offer any advice? The car is still under warranty so i will get it in to the dealer. Hopefully i can as others have done back up my problem with a print out of comments from fellow owners.
    Rgds
    Aidi
    [Ex]Admin Duncan's Avatar
    At what point exactly does it do it? Pulling off, coming to a stop, when the you're under load i.e. pulling off in maybe a higher gear than you may have meant to?
    Nov 2007
    Salisbury
    Thanks for the quick reply Duncan.
    It seems most prominent when i come to a stop and put it in neutral. Its mainly after starting up for the first time that day so the engine is cold.
    Having only just noticed it, i will have to do a bit more "testing" to find out if it does it when in gear etc.
    Rgds
    Aidi
  1. juddering
    By scottsabs in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 12:59
  2. juddering
    By REIDY1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 12:53
  3. Juddering
    By sebadee in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2011, 15:08
  4. 2.0T Juddering
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 7th October 2009, 11:56
  5. Juddering at 200 rpm??????
    By raymie.d in forum Engine & Drivetrain
    Last Post: 26th June 2009, 19:02
