Thread: Any Idea
    Regular Member shan's Avatar
    Default Any Idea
    After the Tech 2 yesterday. I'm now having a little issue with my central locking.
    When i press the open button on the remote only the driver's door unlocks.
    I have to press the open button a second time to open the rest of the doors.
    Also when i switch off the engine and remove the key only the driver's door unlocks. "I have the auto lock set on the car"
    It worked all fine before.
    I'm sure it's something quite quick to sort but i have no idea.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Shan, there should be a section in the manual that tells you how to change this to unlock all doors with one press. The way you have it now is how mine is set-up.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    mine has always been like that shan,i thought that was normal my previous car(landrover discovery)was the same.
    @home
    Engine : 1.9 CDTi
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Mine does this now but my old one unlocked all of the doors when I took the key out of the ignition.
    I'm off for a scout in the manual, back in a sec.
    Sorted Guy's
    At the moment it's set to from the factory spec. Only driver's door opens on 1 press on the unlock.
    I'm set to unlock all door's with 1 press of the unlock.
    Thanks chaps.
  1. anyone got an idea?
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 17:17
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
