Thread: Trouble on start up
    Jul 2006
    Mexico
    Thumbs down Trouble on start up
    This is the second time in 3 weeks that the beast wont start at the first attempt. Outside temp. no cold at all (17 c`s) first and second attemp the engine starts but after 1 second the revs drop down and stops....third attempt of start up you can feel the revs playing up and down a little and after 3 secs the revs normalizes.
    Any ideas what can be causing this? I would like to solve this before it gets worst...
    Mileage : 000
    Could it be the Air contol valve on the side of the throttle body, have you tried spraying Carb cleaner down the top of the throttle body and into the hole in the inside where the air control valve is, or remove the air control valve and give it a good clean with carb cleaner.
    Jul 2006
    Mexico
    Quote Originally Posted by ed taylor View Post
    Thanks Ed for the reply If I`m not mistaking you mean the metal body with a round flap just right out the air box right? If that is the case I looked at it 2 months ago and it was clean as new. I`ll check it again to start eliminating options.
    Mileage : 000
    Quote Originally Posted by BlueRob View Post
    Yep thats the one, it goes into the inlet manifold.
    Jul 2006
    Mexico
    Ah! cool! I`ll check it today and see how it looks
    BTW Ed if that is how beer is drank by women in your country I`m moving to that side of the world ASAP!
    Hertfordshire
    I'd start with the obvious and get it plugged into a diagnostics machine and see if any fault codes come up.
    Jul 2006
    Mexico
    Quote Originally Posted by Green Growler View Post
    Thanks Martin, if nothing obvious pops my eye I`ll plug it and see waht comes up
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    You will not get any fault codes unless your EML light has been on.
    I would not bother with any carb cleaner, after all it is really designed for what it says on the tin and will do little for a throttle body.
    Throttle bodies can be cleaned, but dont undo the screws that hold the butterfly valve in place or that can lead to all sorts of trouble. I personally wouldnt bother with the throttle body.
    I have the same problem and managed to get an almost new throttle body, and whilst it drives much smoother, it still starts badly.
    Mine does start very well when cold, first thing, but no so well when warm ish!
    Once started its perfect, idles perfect, etc.
    Air mass meter, possible??? Why no EML though!
    Mileage : 000
    On the wifes Vecra B she had problems with the air control valve, and by cleaning the valve via the little hole in the inside of the throttle body, it cured the iratic tick over, but in the end I had to fit a new air control valve as the return spring had lost some of it,s tension so the valve was never in the right place when it should have been, But the air mass meter is also a posibility.
    Jul 2006
    Mexico
    Thanks Symon and Ed...I`m taking notes of all
    Yeup I havent seen any falt light on, never the less I just found a place where I can get the codes read FOC , I`ll give it a try and see what codes pop up.
  1. start up trouble
    By rob warrington in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2010, 20:55
  2. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  3. Am I in trouble?
    By Happy Girl in forum General Chat
    Last Post: 1st July 2010, 12:59
  4. Anyone else having trouble
    By ianuk in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 19:57
  5. Air con trouble
    By mikec in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 10:32
