Results 1 to 3 of 3
Thread: Oil warning light comes on when idling
    Regular Member martutd's Avatar
    Lancashire
    confused Oil warning light comes on when idling
    Hi,
    I have a Signum 2004 2.0 Dti, it has done 25000 miles & recently the oil pressure warning light has started to flicker on when the engine is idling, (i.e when I'm stationary). I have just had the oil & filter changed (& checked the oil level) & this has made no difference.
    The light goes off, when I set off or rev up.
    Any ideas? Is it leading up to a bigger problem?
    Cirencester
    i had the same problem on my old 'B DTi, nothing wrong with the pump or oilways, just a dodgy sender unit on the back of the block. as soon as you rev it by a couple of 100 rpms it went off and was all ok
    Jul 2006
    Mexico
    Yeup! probably a faulty level sensor
  1. what is this warning light for?
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2011, 22:03
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. 2.2dti spanner light at idling?
    By bigben in forum Engine & Drivetrain
    Last Post: 27th January 2010, 21:05
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
