Thread: How do I wire in the rear tweeters?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default How do I wire in the rear tweeters?
    Hi all,
    Have had the rear tweeters lying about for a few months. Have now decided to fit them. So who can tell me where I attach the wires?
    Feb 2006
    Guttedsville
    Me. I did it on the old SRi.
    Remove door cards.
    Remove main speaker.
    Look at the plug, you'll see it actually opens.
    Strip new wires and feed into plug.
    Snap plug shut.
    Crimp baby terminals on the other end of the wire.
    Plug those into the tweeters.
    Reassemble.
    Once door cards are off, it's a 15 minute job per side.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Thats great, thanks for the info. Will have a look at the weekend. Not being into ICE I did not know they connected to the speakers like that. I assume that there is a plus and minus to match up but that should be easy to work out. Thanks again
    Feb 2006
    Guttedsville
    Piece of pi$$.
    Connect them, if it doesn't sound quite right, swap them around.
    Oct 2007
    Shropshire
    While you go to the effort of taking the door cards off put why not up-rate them?
  1. rear tweeters
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2012, 16:10
  2. Rear door tweeters?????
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2011, 19:45
  3. rear tweeters
    By phil0464 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2009, 21:47
  4. Rear Tweeters Again
    By AndrewTi in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2006, 18:04
  5. Rear Tweeters
    Last Post: 21st March 2006, 00:34
vectra c no rear tweeter wiring
vectra c rear tweeter cable
