Results 1 to 3 of 3
Thread: 2.0Dti fuel pump
    east sussex
    Default 2.0Dti fuel pump
    My 02 Vectra has an intermittent starting problem which vx says is the fuel pump ecu (apparently attached to the fuel pump) and typically, not sold separately. Does any one know where I can get a new/refurbished fuel pump ecu or alternatively a complete refurbished unit. Any assistance would be appreciated. Thanks
    Portadown, N.I.
    Sorry to hear about your fuel pump problem, I dont like to be the bearer of bad news, but the fuel pump and ECU (like you said, they're 2 parts of the same thing) will need programmed with Vx's tech2 to your car and I dont know if it is possible to re-program a used pump, I have a feeling that they are coded one time only.
    Even if you buy a new, as yet un-programmed pump, you cant just swop it with the old one and drive off, it'll have to be programmed with Tech2 by someone with TIS that has a security dongle, ie Vx themselves or a very well equiped vauxhall mechanic.
    Hope this sheds some light for you,
    Tim
    Full Member Big Sig's Avatar
    Are you sure they are right and its not the leak off pipes?
  1. Vectra 2.0DTi fuel pump failure
    By Davyturner in forum Engine & Drivetrain
    Last Post: 29th January 2013, 17:33
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. 2.0dti Fuel Pump - Need Help Finding Cure
    By JonnyB in forum Vectra C / Signum Troubleshooting
    Last Post: 9th July 2010, 11:16
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
