Results 1 to 10 of 17
Thread: CD removal
    Larkhall
    Default CD removal
    Is there an easy way to remove the cd player??!!
    I've removed the screws, 'borrowed' a set of removal keys from work and taken out the fake buttons but the thing won't budge!!
    2 guys at work have tried, and these are people who remove/fit cd players everyday.........
    I've also noticed that the interference on the radio stations gets worse when i press the rear window demister button
    scotland
    should slide out wi the keys mate,
    I done it wi 4 drill bits inserted and pulled it out !
    as for other buttons you've either disturbed some wirin or its been like that b4 and you've not noticed.
    Larkhall
    I was fighting with it to try and get it out, i pulled the pins towards me but it wouldn't move!!
    Any ideas as to how the demister button is interfering with the aeriel?
    scotland
    try pushing the pins slightly outward and pulling
    as for the de - mister I'm assuming there is a bare wire in behind the buton or somewhere behind radio unit ?
    Larkhall
    I'll try again on Wednesday when i'm off
    [Ex]Admin Duncan's Avatar
    The demister/radio issue could possibly be linked to the actual demister maybe?, as the aerial is close to it. I'm sure the wiring for the two of them runs together at some point - could be interference from the demister wiring, which there's a fault in?
    Larkhall
    Am i best to check it out myself first, then let the dealer know?
    They aren't a VX dealer but would they be able to fix any problems, should there be any?
    Regular Member DeathStar's Avatar
    UP North
    yes I would say they could. If they could not they should take it to VX
    Depends on how confident you are fiddling around with wiring looking for any problems. It could just be the switch as already mentioned. If you're not up to having a dig, then you at least want to get an auto electrician to have a look if it's bothering you that much.
    Larkhall
    The interference on the radio wasn't bugging me that much, but now i've noticed it gets worse when the demister button is pressed i'm starting to worry it may start a fire as the rear demister is on all the time
  1. dpf removal
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 10:53
  2. Tar removal
    By Jim Bob in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 20:18
  3. Cat removal & EGR
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 16:58
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. Tow Bar Removal
    By korlinski in forum Bodywork & Interior
    Last Post: 30th April 2007, 21:19
