Thread: Exhaust Gases Indicator ?
    scotland
    Default Exhaust Gases Indicator ?
    this light came on today when I started up as normal but it aint going out ! tried switching it on and off again but its remaining on .
    could this be a multitude of probs or can it be pinpointed without goin to the stealers to have it diagnosed for one arm and one leg!!
    i.e. most likely causes??? EGR valve ? any ideas lads?
    Jul 2006
    Mexico
    I`m affraid the best way is to have a read on the fault codes mate...I think you can have an independent garage to check them for you, might be cheaper than a dealer....
    [Ex]Admin Duncan's Avatar
    You're meaning the emissions light? If so, it could be a multitude of reasons. All it's indicating is that the sensors are picking up readings that are out of range - it could be the lamda sensor playing up, or a multitude of other possible reasons. You'll really need to get the car read to see what codes are stored.
    If the light is steady then it's not so bad, but if it's flashing then you need to really stop driving and get it looked at as you could kill your cat.
    scotland
    thanks gents as I thought , it is on constant and not flashing so assuming its not the cat ! i'll get it read from a friend and if its only egr or something I will repair but if more to it it might be ££££££££ am affraid ....... ouch
  1. de-cat = very smelly exhaust gases
    By ditchp in forum Diesel Engine related
    Last Post: 8th February 2012, 20:15
  2. exhaust gases light?
    By vectra-matt in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 19:42
  3. Exhaust gases light on. :(
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2009, 19:36
  4. exhaust gases sign
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2008, 13:52
  5. Car and Spanner / Exhaust Gases Lit
    By Ridaz in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2008, 21:18
exhaust gas light on 58 vectra diesel
