Thread: Best way to dry out carpets?
    Regular Member varadero's Avatar
    May 2007
    leeds
    Default Best way to dry out carpets?
    A quick question on the best way to dry out my passenger carpet.
    Had a bit of a leak (the drain under the pollen filter was blocked) and this
    has filled the passenger side footwell with water,not just wet but standing water on top of the carpet.
    Have soaked up as much as possable but the carpet is still very wet.
    Any ideas on the best way to dry it out fully.
    [Ex]Admin Duncan's Avatar
    You may want to hire/borrow a wet 'n' dry vac thing with a nozzle. That'll suck off a good bit of the excess. Then it's a case of leaving the doors open to let it dry off. Ideally in a warm place like a garage/unit where you can heat the room up and leave the doors open as not much is going to dry in the current temperatures.
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Just dont try to dry it out by leaving the heater on in the car.
    You'll be getting steamed up windows for weeks.
    When I was in the trade we used to dry out car carpets by putting the car in garage opening doors and using fans, like desk fans etc. just to blow cold air in through the open doors. Circulating air is q'kest way to dry them.
    May 2007
    Doing stuff
    Use old towels soak up as much as possible, then lift the carpet and use a haidrier.
    If you leave it too dry eau naturel it will provide a not so pleasant aroma and the cat will steam up for a good few months.
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 192000
    Quote Originally Posted by varadero View Post
    has filled the passenger side foot well with water,not just wet but standing water on top of the carpet.
    Have soaked up as much as possible but the carpet is still very wet.
    i had the same thing happen to me last week
    http://forum.vectra-c.com/showthread.php?t=35097&page=2
    Quote Originally Posted by smithi View Post
    Use old towels soak up as much as possible, then lift the carpet and use a hairier.
    If you leave it too dry eau neutral it will provide a not so pleasant aroma and the cat will steam up for a good few months.
    Exactly what i did, took about 45 minutes to do but it's dry now
    May 2007
    leeds
    Thanks for that, going to sit in the garage with the wifes hair dryer for the next hour or so.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Hot Water Bottles.
    Worked for me last year on my old B.
    Jun 2007
    Vehicle : Vectra c
    Year : 06
    Mileage : 192000
    Quote Originally Posted by BigMan View Post
    Hot Water Bottles.
    unless they leak, then your stuffed
    Jun 2007
    Quote Originally Posted by al21784 View Post
    No, your no worse off than before, so you go and get the Hairdryer out!
    Jun 2007
    Vehicle : Vectra c
    Year : 06
    Mileage : 192000
    true
  1. Wet carpets!!!!! help
    By yorkiebar in forum Bodywork & Interior
    Last Post: 24th March 2011, 19:34
  2. wet carpets
    By xf8u39 in forum Bodywork & Interior
    Last Post: 1st February 2011, 09:09
  3. Carpets Wet
    By KN1 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2009, 19:27
  4. Wet Carpets
    By PYNE999 in forum Bodywork & Interior
    Last Post: 8th March 2008, 01:35
drying vectra c carpets
Best way to dry car carpet
