Results 1 to 10 of 28
Thread: Engine block 'idiot light' ON!!!!!
    Newcastle upon Tyne
    Default Engine block 'idiot light' ON!!!!!
    What the "ell does this signify,is it about to self destruct or is it a common glitch that can be cancelled,why does it happen?
    Regular Member Basil's Avatar
    Nottingham
    If it's the one I'm thinking of, the car's software has gone into 'limp home mode'.
    It normally tells you theres a problem somewhere, I don't know if there a way to DIY turn it off, you normally have to go to Vx so they can diagnose the problem.
    Newcastle upon Tyne
    Its the engine block shaped light,bottom right of dash,comes on when ignition is switched on and should go off after startup.
    Nottingham
    Quote Originally Posted by cb500t
    That's the one.
    It means there is a problem and needs to be checked at a dealer.
    Is your car still under warranty?
    Mileage : 000
    it sounds like one of the many sensors may have malfunctioned, if it is still under warranty you should be ok, the hot air flow mass meter packed up on the wifes vectra b last week, i was able to find the fault with "the paper clip test" but the part still cost me £ 120 trade..
    take care
    ed
    Newcastle upon Tyne
    Yes bought car 4 months ago when it was 6 months old from dea;er so have Network Q and remainder of manufacturers
    Newcastle upon Tyne
    After 2 visits to the dealer,they found its an oxygen sensor,which they don't hold in stock!!!!,and after much pressure from me they also decided rear screen needs replacing as a heated element has failed,so car has to return for the 3rd time............but plus point was my annual oil change at 8000 miles only cost £57 bargain!!!!!!!!!!!
    Walsall, West Mids
    Good morning
    I'm having this same yellow engine block light problem on my 1.9CDTI, 55 plate.
    I've recently fitted a 2nd hand turbo and EGR valve, the latter being fitted approx 6 months ago as the same light came on then and was told it was the EGR valve then,
    It came on again 2 days ago and wont go off !!! After reading a few posts on here, a couple of here have suggested cleaning something with carb cleaner, but i'm not that technically minded !!! Is this an easy job and what exactly do i have to do to clean this mysterious part or parts ??? Or any other suggestions ??
    Whats making it worse is that the car is actually up for sale so i need to get it sorted asap !!!!
    Feb 2011
    Selby
    You need to read the fault codes. Anything else is just guessing...
    Walsall, West Mids
    Thanks for the tip Rich - i thought that would be the answer. There's a garage local to me here that will check it out for me for a drink, just called them and they will look at it Sat morning for me - earliest i can take it down.
    Just hoping its nothing to do with EGR or Turbo again !!!
    Will update as and when - thanks again mate
  1. engine block painting
    By Caveman_nige in forum Styling
    Last Post: 6th May 2012, 07:17
  2. lifting an engine block by hand
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 10:34
  3. soot on side of engine block
    By jonestown in forum Y & Z30DT Specific
    Last Post: 23rd April 2012, 21:46
  4. engine block light on????
    By rab,gsi in forum Engine & Drivetrain
    Last Post: 14th December 2011, 13:43
  5. Where is VIN on engine block
    By manimal in forum Engine & Drivetrain
    Last Post: 25th October 2010, 12:44
