Results 1 to 3 of 3
Thread: Oil Leak
    South Yorks
    Default Oil Leak
    My 1.8 Vectra's only done 5k miles and is already dropping oil on the drive - going to dealers tommorow to book in to get fixed - but anyone experience the same problem and know extent of likely work will be ? -
    The oil appears to be coming from the top of the engine (offside) above what appears to be the water pump, coming from behind a plastic cover which looks like it could be the cam belt cover - could it be a cam shaft oil seal leaking. There's not a lot dripping yet, although there is a trail of oil down the side of the engine ending with a large area of the bottom of the engine covered in a greasy mess - all the more obvious due to it been almost new.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Is yours the VVTi?
    I've had problems with my 1.8 (non-VVTi) with leaks from the rear main oil seal, but as you say that yours is from the top it won't be that so it does sound like the camshart seal to me
    South Yorks
    Quote Originally Posted by JuzzyD View Post
    Is yours the VVTi?
    Yes its VVTI - will post VX solution when work completed.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
