Thread: sounds like water in my gearbox??
    tiverton
    confused sounds like water in my gearbox??
    hi, can anyone help, i went through a few deep puddles (small floods) the other day and since ive has a noise coming from my gearbox, it sounds like the gears are splashing around in water, but when the car has warmed up i get a winning noise every time i put my foot down to go faster. could it be that ive got water in my gearbox or is it something else?
    any ideas???
    Mileage : 000
    Manual or auto, the only place the water could get in is through the breather, and you would need to go through some very deep water for some time or be stationary for the water to seep in. The thrust bearing might be at fault though.
    tiverton
    hi and thanks for replying so quickly. its a manual gearbox. where is the thrust bearing? and would it make a wineing noise when its ****ed?? the noise is coming from the passenger side of the car. im still confused
    Mileage : 000
    The thrust bearing is in the bellhousing, where the clutch is, it is on the right if veiwed from looking into the engine bay, that is probably why you say the noise comes from the passenger side, as that is the side it is on, does the noise change when you "dip" the clutch pedel?
    PS if the thrust bearing is "knackered" it will whine.
    tiverton
    yes when i dip the clutch the noise goes. ive also noticed that when i put it into gear and lift the clutch up thats when it makes the noise, and it will whine when im at a stedy speed.
    thanks a lot for your help.
    Mileage : 000
    Sounds like you need a new thrust bearing. you might as well have a new clutch at the same time.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Auto Gearbox - Can you prevent Water Contamination?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 3rd December 2012, 15:17
  3. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  4. Signum Water in gearbox court case vs motor trader
    By mikaj in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 11:06
water noise in the gearbox area
watery sound in my gearbox
