Results 1 to 10 of 17
Thread: Brake Pad Tool Advice !!
    Regular Member Cilldara1's Avatar
    Northolt
    Vehicle : Insignia SRI CDTI
    Year : 2012
    Mileage : 28000
    Default Brake Pad Tool Advice !!
    Evening all, need to change the Front & rear Pads and came across this Brake Piston Cube from Sealey. Just wondering if any of have one of these and if there suitable for the Veccy C all in costs about £11.00 quid...
    If this will do can't go wrong at that price !!
    Site states below
    Suitable for vehicles with discs all round. Retracts parking brake piston prior to installation of new pads. Five possible pin configurations, fit US and European applications. Use with 3/8Sq drive ratchet wrench and extension bar.
    Warning: Not for use with impact type ratchets.
    * Suitable for vehicles with discs all round and retracts parking brake piston prior to installation of new pads.
    * 5 Possible pin configurations fit US and European applications.
    * Model No. VS039
    [Ex]Admin Duncan's Avatar
    I'm trying to get my head around how it would work - given that you need to compress the caliper from both sides to wind it in.
    Northolt
    Year : 2012
    Mileage : 28000
    No Idea Duncan, I was under the impression that you would find the Suitable pin side, place it against the Piston and use the Ratchet to Screw it home ?? unsure what you mean by having to compress the Caliper from both sides to wind it in....
    I take it this may not be suitable for the job then ???
    My concern was that the Cube may be too big to fit between the Piston and Caliper! now I have something else to think about
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    i mentioned something similar a while back. see thread
    http://forum.vectra-c.com/showthread.php?t=26740
    member of the smoke patrol 230bhp+
    you need to be able to push the piston back aswell as turn
    for a few pounds more get the right tool for the job
    Ah thanks John, saved me a bit of typing. I was basically going to say that it wouldn't let you push the piston in at the same time as turning.
    Here's my rewind tool...
    As you can see, the black plate sits on the face of the caliper to then allow you to exert the pressure by turning the threaded screw.
    Also, I don't think that cube would even fit properly in the caliper.
    Northolt
    Year : 2012
    Mileage : 28000
    Quote Originally Posted by chrisgettings View Post
    Going to buy the lazer tool off e-bay......
    As you said right tool for the Job,
    However
    If the Cube fits o.k surely it would be better than using a Snipe nose pliers or a home made tool as some have done, after all does it really require a lot of pressure to wind the Piston in ???
    Ignore the above !!! just seen Duncan's reply !that it wouldn't let you push the piston in at the same time as turning.
    ! many thanks Duncan this answers all my Questions........
    No probs. Also, in reply to one of your questions above, it's not a case of it (the piston) needing a lot of pressure but slow even pressure - something that can be easily controlled with the right wind-in tool.
    Northolt
    Year : 2012
    Mileage : 28000
    Sweet, again many thanks.......
  1. Brake tool
    By dalecheesy in forum North East RO Vacant - ARO - Vacant
    Last Post: 5th April 2012, 01:58
  2. Brake rewind tool (which one)
    By Middo in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2011, 17:27
  3. Brake rewind tool
    By jackster in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 20:48
  4. brake rewind tool
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 16:24
