Thread: fault code
    Central Scotland
    Default fault code
    Evening all,
    anyone any idea of what could give me the following fault code:
    P0234 - Boost Pressure Control Circuit Positive Deviation
    (5B) - Not present
    I think this has something to do with the turbo pressure.
    The fault light came on when accelerating up a hill in 4th gear joining the motorway, speed approx 55mph if that helps.
    This fault brings on the car and spanner symbol on the dash. It resets if I turn the ignition off.
    Regards
    Ian
    Feb 2006
    Guttedsville
    What engine?
    Central Scotland
    Whoops sorry,
    52plate 2.0DTi
    Ian
    Feb 2006
    Guttedsville
    Could be either the boost sensor or possibly a split boost or intercooler hose.
    Check the hoses visually, makeing sure you check them all round and thoroughly, the boost sensor plug may need a bit of a clean up and refitting.
    Past that, it really could be allsorts!
    Central Scotland
    Where is the boost pressure sensor?
    Ian
    Feb 2006
    Guttedsville
    I knew you'd say that!!
    It's down the front of the block, underneath the EGR valve and housing. Look for a small black plug, with two wires coming out and going into the loom.
    Central Scotland
    Thanks for that. I will have a look tomorrow and see if I can find anything.
    Regards
    Ian
    Central Scotland
    Had a look under the bonnet today and found a burst hose connector at a solenoid located under the bonnet catch panel just to the left of the battery box. This has a hose connecting it to the vacuum pump and the boost pressure regulator so hopefully this might be the problem. I have cut away the burst part of the connector and refitted it but I think I will be better to get a new hose and connector from vauxhall tomorrow.
    Regards
    Ian
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
