Thread: Vec' Headlights & Fog's
    Regular Member B19CBB's Avatar
    Nov 2007
    North East
    Vehicle : Insignia
    Trim : Sri Nav VxLine
    Engine : 2.0 CDTI 160 ps
    Year : 2011
    Default Vec' Headlights & Fog's
    Can you replace your fog bulbs without going to VX like it says in the owners manual? If so how do you do it?
    And can you replace them with a higher watt bulb, i did this with my headlight bulbs (55w-out / 100w-in) had no problems???
    Jul 2006
    Do you do a lot of night-time rally stages up your way then? I believe anything over 55W is not only damaging to the headlight reflector, but also a possible MOT fail.....
    Nov 2007
    North East
    Vehicle : Insignia
    Year : 2011
    Only at the weekend!!!!
    I drive alot at night and early hours of the morning and had to do something to improve the lighting issue.
    Regular Member eaglepva's Avatar
    Up North
    Have you had any problems with the 100 w bulbs i was thinking of putting them in my siggy as i do a lot of early morning driving on country roads.
    Jul 2006
    Mexico
    I will not recomend using a bigger bulb (watts) the electrical connections might fail do to the exxxes of current needed....they might heat up to much the wires...
    You can get same wattage bulbs that deliver a little stronger beam IMO
    Nov 2007
    York
    BlueRob is absolutely correct. If you upgrade from a 55w to a 100W bulb you need to replace all the wiring and the relay in the circuit since you are drawing virtually twice the current. Also, anything over 55W in a post 1992 car (or is it '84?) is against construction and use regulations and hence illegal.
    Having said that, the vectra puts out so little light, i doubt anyone would notice Just need to watch out for those melting wires!
    James
  1. Yellow fog's?
    By k9vnd in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2013, 21:23
  2. A2/M2 Vec' Estate
    By Jekyll & Hyde in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 21st June 2012, 23:28
  3. Headlights.!!!
    By Vectra boy in forum Troubleshooting
    Last Post: 5th January 2012, 15:24
  4. Road Rage (Vec' B VS Corsa)
    By B19CBB in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 20:45
  5. Front Fog's
    By Electric Blue in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 16:15
