Thread: Door Membrane
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Default Door Membrane
    Have found that one of my door membranes has been butchered, the plastic sheet behind the door card, and just need to know if this is available as a separate part or is a trip to B&Q in order.
    Jul 2006
    How badly butchered is it? It's really only to stop any damp getting into the door card, you could equally well use a bin liner and duck tape....
    [Ex]Admin Duncan's Avatar
    Yep, you can buy them separately from the dealers. You can also buy better stuff as I did - http://forum.vectra-c.com/showthread.php?t=9323
    Nov 2007
    Northants
    Took your advice and made one up as only had about half the factory one left, many thanks. Dont you just love the main dealer care and attention!!!
    11 Post(s)
    Quote Originally Posted by parapaul View Post
    I thought it was also necessary for the side air bags to function correctly in the event of a side impact as the sensor relies on pressure differences, and if the membrane is torn then the sensor won't operate the airbag.
    I've never heard of that, and can't see how. The membrane doesn't really hold back any pressure. It can't, as it has slits in it for the bowden cable for the door release for example and the door locking pin rod. I've only ever been aware of it there for the reason Paul said, as a moisture barrier.
    Also, I didn't think the side impact sensors were in the door voids either?
    11 Post(s)
    Duncan, only commenting on what I previously read somewhere, with several people confirming it. This was however relating to a Vectra-B. Vec-C set up may well be different.
    Sure, I wasn't saying you were wrong as such. From having replaced my membranes as above, I just couldn't see how the membrane could hold any significant pressure in the door void to affect how the impact sensor worked. Just off to see where they are actually situated....
    11 Post(s)
    I have to agree, it does sound weird, what with all the other places pressure can leak out though in the door. eg, door bottoms, stay catch, around the bottoms of the windows, etc.
    Yep, I never did suss out where the impact sensors were either so no extra help there.
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. A good door to door courier for an exhaust?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 21:19
  4. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
cdti door membrane
vauxhall door membrane
