Results 1 to 2 of 2
Thread: Suspect Injector Problem
    Regular Member DAVO's Avatar
    Nov 2007
    WEST MIDS
    Default Suspect Injector Problem
    Any body got any quick fix ideas for a kangarooing CDTi 150 Vectra.Vx dealer is saying it's an injector problem and me spanners come up on the dash. I need to drive the car from Brum to Bristol for works do but am a bit scared as it,s also making a heavy tractor like sound.Vx dealer cant help with curtousy car so stumped.Any ideas.Cheers in advance,Chris.
    Regular Member b-e-r-t's Avatar
    Northern Ireland
    When you say it has the tractor sound, im guessing its off a cylinder.
    It could be an injector thats givin up the ghost which is easily fixed, if pricey.
    Other hand it could be the injector loom (or one of its connectors).
    I have a problem with the injector connector on my 3rd cylinder (see post i made today) - it is bringing on the spanner light and causing a bit of the kanagrooing - worst when you have very little throttle down.
    When the car is idling, try moving each connector in turn back and forward a bit - just wiggle it. If the car idles properly (even for a short while) while you are fiddling at it, you know its the connection. If not, its probably one of the injectors.
  1. Injector Problem
    By vectra19 in forum General Motoring Chat
    Last Post: 8th June 2012, 23:40
  2. 150 injector problem
    By lee640 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 21:13
  3. suspect faulty injector 1.9 cdti 150
    By blakester9 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 22:17
  4. Suspect Turbo-related Problem
    By phughes64 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd July 2010, 11:46
  5. 3rd injector problem
    By smurfy in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:56
