Thread: CDC 40 Opera where to connect the carkit?
    Regular Member throdo's Avatar
    Jun 2007
    Greece
    Question CDC 40 Opera where to connect the carkit?
    Hello, I just added a nokia ck15w carkit. Below is the diagram of my cdc40 opera radio. Where should I connect the carkit speaker output? (I don't have a fakra/iso connector but I don't want to damage the unit just trying randomly. The local dealer guys don't have a clue)....
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Can you post a close up of the label please and I'll see if I can identify them for you (specifically the bit on the left)
    As an aside, have you checked for the phone loom behind the glovebox?
    Jun 2006
    Somewhere...
    http://forum.vectra-c.com/showthread...ghlight=carkit
    This should help as the CD70 and CDC40 use the same connector - if you rotate the CD70 pic by 180 degrees you should find it matches up with yours
    Therefore you need the Phone In + , Phone In - and Tel Mute pins shown. The permanent power will need to be taken from elsewhere (the cigarette lighter/accessory socket for example).
    Hope this helps.
    If you have the phone loom lead behind the glovebox it will be even easier to do as it has all the necessary cables!
    Jun 2007
    Greece
    Thanks for the hints!!
    A close picture of the CDC 40 unit
    Jun 2006
    Somewhere...
    Yep, Tel Mute's obvious on the label, the Phone Inputs are marked as PH+ and PH- and are on the bottom right. HTH
    Feb 2011
    london
    Default cdc40
    Quote Originally Posted by throdo View Post
    where the sub wires are going ? wher u ned to conect the sub or just cut it
  1. Cdc40 opera dab, how can I connect my sub/amp???
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2011, 17:47
  2. IO Talk1 Carkit
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2010, 14:52
  3. bury cc9060 carkit
    By stuart bigboy in forum General items for sale
    Last Post: 20th December 2009, 12:26
  4. bluetooth carkit fkitting
    By graememk in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 23:31
  5. Software upgrade for Vx bluetooth carkit
    By sig63 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2007, 17:56
cdc40 mute input
cdc40
cdc 40 opera año 2005
