Thread: Spring clamps????
    Tyneside
    confused Spring clamps????
    Going to need a set of spring clamps in the very near future, so not really to wise in this department and need to know if these would do the job? If these are crap could someone point me in the direction of some desent ones, cheers
    member of the smoke patrol 230bhp+
    yes you can use them,,,,
    there not the best but there the right price ,and remember to zip tie them to the spring to help stop them slipping
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    look ok to me mark i say go for them
    Cirencester
    Hijack
    are springs really easy to fit? same as old vectra b and corsas?
    Tyneside
    Don't know how hard they are to fit, getting a mate to give me a hand.
    Tyneside
    Quote Originally Posted by chrisgettings View Post
    So what would do the job better? I don't want body parts ripped off when a spring goes flying.
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Thumbs up
    Check ebay again you can get the same ones for £6.49(i just typed in spring compressors)
    Tyneside
    looking again these look a bit more sturdy.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The only problem you'll have is undoing the top nut,we had to grind down a ring spanner to fit the nut and a decent torx bit for the strut insert as they are tight.
    morton
    if you use an air gun for the top shock bolt it comes straight un done ! i'd suggest you do that first even if it means taking it to a garage and getting them to slacken it a tiny bit ! will save alot of hassle ! on the back , you can undo the bolt that goes through the bottom arm ! where it meets the strut ! then all you need is a jack of some kind to raise it back into place . only takes 10 mins a side if you use this method !
  1. Anybody Used Lowering Spring Clamps???
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 01:15
  2. Spring Clamps - Are they needed for the rears...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2010, 17:43
  3. Wheel clamps
    By Ste in forum The 'Off Topic' room
    Last Post: 2nd November 2008, 21:43
  4. car Clamps
    By dannysport18 in forum General Chat
    Last Post: 8th December 2006, 09:22
