Results 1 to 10 of 14
Thread: anybody help please
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Default anybody help please
    hi having trouble puting a link up i dont get the option to go in to advanced any ideas on what im doing wrong followed duncans advice on earlier thread
    Go to the item in ebay and copy the address from the address bar at the top.
    Write your post for the forum as normal, but make sure you're in 'Advanced' mode (button next to 'Post Quick Reply' at bottom of page.)
    Highlight the text you want to have the link. Click the Insert Link button in the formatting toolbar.
    Paste the address that you copied from ebay. Same procedure if it was another thread on the forum etc.
    Post thread
    Step by step -
    1. Highlight the URL page of what you want to link to. Right click it and select COPY -
    2. Go to the section you want to add a new thread to and click NEW THREAD at the top left -
    3. To inset a link into your thread click INSERT HYPERLINK -
    4. this will open another window. Type what you want to be displayed on your thread in here -
    5. After clicking OK another box will appear. Right click and PASTE in the URL page you copied at the start
    6. Click OK
    Job done!!!
    HTH
    Funny you should mention that. ;-)
    Trim : vxr
    Mileage : 31000
    Smile
    Step by step -
    6. Click OK
    Job done!!!
    HTH
    hi aja i dont have all the icons on that you have on step 3 ie when i want to post a thread i only have the smiley faces at the bottom of the window if you can understand what i mean. stil learning with computer m8 sorry to be a pest
    did you click the Activate Account link on the e-mail that you were sent when you signed up?
    failing that - it's over to Duncan to check your account.
    Trim : vxr
    Mileage : 31000
    ye m8 done all that is it something to do with my settings i have? im sure the icons where there at the start must be something i done or switched of?
    Hi David, A quick check,
    Go to user cp, edit options,
    At the bottom there is a Miscellaneous Options, check you have it set to Standard editor and not basic as this would have the effect you describe.
    T.
    Trim : vxr
    Mileage : 31000
    Smile
    thanks m8 thats been the prob all sorted now im learning
    No Problem dude ...
    [Ex]Admin Duncan's Avatar
    David. I've looked at you settings and I can't see why you shouldn't be able to see the icons in the editor box. Have a try yourself.....
    Go to your User Control Panel
    Choose Edit Options
    Scroll down to the bottom to Miscellaneous Options
    According to your settings that I've looked at, you have the forum default of Standard Editor - this will have the icons that you need for adding a link etc. Choose Enhanced Interface to maybe see - or choose Basic Editor, save changes, come back and choose Standard again.
    If you have either Standard or Enhanced chosena and are still not seeing the icons, it's a browser issue. Are you using a different browser than before, or an older version of a browser. Firefox and IE6 both work fine for me.
    HTH
