Results 1 to 10 of 14
Thread: will astra vxr brakes fit a vectra 3.2 GSi ???
    Jun 2007
    Sittingbourne, Kent
    Default will astra vxr brakes fit a vectra 3.2 GSi ???
    as above and are the vxr brakes bigger than the GSi has ??? has the vxr vectra got the same size brakes ???
    Thanks in advance ...
    Jan 2006
    Hornchurch
    no they will not better to look for a set off a vectra vxr
    Tyneside
    You can get the Vectra VXR brakes from Courtenay, IIRC around £750
    Regular Member muffking's Avatar
    I can't remember the size of the VXR brakes, but they do fi if you change the calipers too.
    Although I've been able to hammer the GSi brakes round a track since upgrading the discs, pads & brake fluid
    Tyneside
    Quote Originally Posted by muffking View Post
    So there was no brake fade or at least not a lot, interested as I might upgrade to the GSi set-up.
    Regular Member integrale's Avatar
    Nov 2007
    Mansfield Woodhouse
    You have a pink car.....
    Quote Originally Posted by mark1319 View Post
    I felt the brakes cook a couple of times at the end of the main straight after braking from 110mph into a tight 30mph bend a few times but they soon cooled again for the rest of the lap.
    I'm happy to leave them as they are now, but I think that fitting the EBC redstuff pads made a big difference as they are high temperature pads.
    Quote Originally Posted by integrale View Post
    Nope, just a reflective one & a red fence
    Nov 2007
    Mansfield Woodhouse
    I guessed it was something like that.. your brakes look good by the way.
    They work really well too. You can really stamp on them even when very hot.
    Nov 2007
    Mansfield Woodhouse
    I had tarox ceramics on my Delta for a while £1000 a throw, meant to be a lifetime disk..........lasted 4 months..
    The ceramic was so good it was the case of whats behind you....
    I now have the tarox G88, ****** horrible want to change them as soon as possible...
  1. 314 mm front brakes off astra h sri xp
    By mutley-k666 in forum Handling & Braking
    Last Post: 20th January 2013, 14:46
  2. Would Astra or Zafira VXR brakes fit a Vectra C
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2012, 13:58
  3. Astra VXR brakes
    By veccyjim in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 00:34
  4. Will Astra VXR brakes fit the Vectra C?
    By Telly Addict in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2009, 20:27
  5. Astra VXR Brakes
    Last Post: 21st January 2009, 16:54
