Thread: Fitting Nokia bluetooth
    Nov 2005
    Wirral
    Default Fitting Nokia bluetooth
    Has anyone fitted the nokia bletooth kit to their veccy, and if so is it difficult? I fancy getting it of Father Christmas this year since I have been a good boy all year. My only problem is that if I can save myself £140+ in getting it fitted by a technician (spotty teenager with a Nova) i would be happy. I have a phone kit already fiitted from when I bought the car so can I use some of the wiring from this to save me dismantling the whole dash?
    Any ideas appreciated
    Paul
    Preston Area
    piece of cake if you have the telephone pre wiring in already... 5 mins of a job with correct autoleads adapter, otherwise it'll be an autoleads job into the wiring loom behing the stereo, and a 10 min job! ( after you work out how to get the stereo out! )
    I fitted one to my Vectra last weekend.
    My car's got the CD30 headunit which supports telephone mute and line-in so I opted for an Autolead (06-122B, ~£40) which sits in between the original harness and the head-unit and provides power, ground, mute and audio connections. It plugs directly into the Nokia module. You do need to source a separate ignition-switched supply but you can pick this up from the cigar lighter. (The bullet-type connector fitted to the lead happens to locate nicely in the rear of the cigar lighter connector so in the end I didn't have to cut or splice a single wire.)
    However, if you're not worried about muting the stereo and can live with a separate speaker, it's entirely possible to fit the kit without any third party lead.
    The hardest part is routing/stowing the wiring. I found a convenient location for the control module alongside the head-unit (behind the hazard light switch). Try and point the antenna end of the control box towards the passenger compartment. Also see here:
    http://www.vectra-c.com/forum/showthread.php?t=3332
    for how to remove the light-switch.
    Nov 2005
    Wirral
    Thumbs up
    Cheers Chaps, Mucho Appreciated
  1. Fitting a Nokia CK7-W Bluetooth Kit
    By blackviper90210 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2012, 10:42
  2. nokia bluetooth car kit fitting without vda
    By Scotlad in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2012, 14:50
  3. nokia bluetooth car kit
    By stuart bigboy in forum Parts for sale
    Last Post: 25th February 2009, 21:56
  4. Nokia CK-7W Bluetooth car kit
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2007, 21:14
  5. Nokia bluetooth car kit
    By jamesr in forum Parts for sale
    Last Post: 14th June 2007, 16:39
