Thread: question about air-con
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Red face question about air-con
    when i have my air-con on and i drop the temperature below 17 it comes up on the screen low,does this mean i need the air-con serviced?
    never had air-con before so not sure excuse my stupidity
    Regular Member simon5800's Avatar
    May 2007
    derbyshire
    dont think any air con wil go below 17 as it cant cool it any further, well none of the ones i have ever used will do, not just car ones
    Oct 2007
    Back in Belfast!!!!
    cheers simon just was not sure.
    May 2007
    derbyshire
    no worries, i may not be 100% correct but im sure they is a min temp they can do or one where past a certain point it is un economical to cool further so that may be why. need some scientist here
    Regular Member DeathStar's Avatar
    UP North
    I think it means it stops acting as CC and starts working as AC and just tries to cool and not maintain a temperature.
    Regular Member Ian's Avatar
    York
    yep my old golf that had dual zone CC did the same. turn to 17 degs then one more click down and the display would just say low and the CC turns off and the car works like standard aircon. I do miss the CC though. Its fun getting in the car when the weather warms up and hear the aircon kick in by itself.
    Jun 2007
    Black Country
    it says LO cos thats the lowest setting you can go to, same as when you go the other end you will get HI as the highest setting
    Oct 2007
    Back in Belfast!!!!
    cheers fella's question well answered
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by Guyver1 View Post
    Not the lowest setting, just means that it will keep cooling as opposed to maintaining at a constant temperature. The Hi setting means the opposite ie will keeping heating.
    [Ex]Admin Duncan's Avatar
    From the manual......
    If a temperature below 16 °C is set, Lo
    appears in the display: the electronic air
    conditioning system runs constantly at
    maximum cooling power. The temperature
    is not regulated.
    If a temperature above 28 °C is set, Hi
    maximum heating
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
