Thread: Noisey Rear End
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Noisey Rear End
    OK,had the car for a week now.Worried about the noise from the back of my car.Originally thought it was due to the uneven and low pressures.After inflating both to 33psi...still got the noise.Took it to my mate/mot tester and man who can when i cant! After checking the bearings he said both were fine BUT both rear brakes are dragging.
    Any ideas? strip down and clean?New discs and pads?..
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    You can inspect the disc and pads.
    If there is little brake pad left, then yes replace, 3-4mm would be low.
    Is there a big lip on the edge of the disc? Are the discs scored, etc? If yes, then replace them, its not that an expensive do.
    If you do the work yourself, the rear caliper cylinder requires a brake rewind tool to wind the cylinder back home. It must not be pushed in like the fronts can be.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if the brake's are binding ask your mate to have another look and see if he can sort it out for you, or if you brought the car from a dealer's ask them to sort it out
    Midlands Mod Shop - NFFC.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Was going to see the dealer re.getting the car tracked etc.Wanders to the left n vibes over 70.. but im not gona hold my breath.the lists getting longer...
    Trim : Get a
    was it a vx agent or an indipendant garage ??????
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Independant dealer im afraid.Small,20 yr old buisness,
    Guess im gona see just how good his 3 month warrenty is!
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by nikroc View Post
    Just out of interest, manual states recommended pressure of 35psi all round on the 2.0T with 17" wheels.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks for that John K sri.ill up the pressures fom 32 when the tyres have cooled down later,
  1. noisey shocks?
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2013, 21:02
  2. noisey 2.2 dti engine
    By peadar in forum Diesel Engine related
    Last Post: 7th July 2011, 19:21
  3. Noisey air con fan
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 08:10
  4. Noisey Pulley
    By neilb1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 19:55
  5. noisey headlight
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 21:17
