Thread: Bad started - only sometimes
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Default Bad started - only sometimes
    Car runs a dream but takes ages to start sometimes.....
    First thing in the morning when its cold, it will fire up no problem.
    But when its cool, warm or hot, it will sometimes turn over and over for a while before finally firing up, then it might idle bad for a split second before it finally realises how it should be running and then its perfect.
    If I then turn it off and try to start it straight away, it will fire first turn and keep doing so.
    Its almost like its getting the incorrect information in order to start it correctly.....
    ideas?
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    z22se 2.2 engine
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if its diesel you have to let the glow plug lights to go out before you star the car
    Jul 2006
    Mexico
    Dont kill me but the Z32 is petrol is it not?
    If that is the case...many things comes to mind, not of them really will fall into the symptoms described....but you can check spark plugs, dirty petrol inyectors...or an ECU fault that might be cured by new software or by reseting it
    Nov 2007
    CUMBRIA
    Default me too!
    i was just about to put the same message on here. my car will start great cold, hot, wet, dry anything. then just now and then takes ages to start and ticks over bad until i give it a rev. i've noticed the battery light stays on when this happens. once i rev it and the idle is back to normal, the battery light goes off straight away. any one have an idea? its a 2.2 petrol.
  1. It's started already
    By neverlandandy in forum General Chat
    Last Post: 14th November 2010, 14:06
  2. It has started
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 19:23
  3. And it has started :d
    By Barker.Vectra.Sri in forum Quick Photo Album
    Last Post: 6th February 2010, 18:29
  4. Has it started!!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2007, 10:54
  5. Its started
    By SelbyVX in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2007, 21:19
