Thread: Omega 2.5 V6 petrol
    Regular Member vecest's Avatar
    Felixstowe
    Default Omega 2.5 V6 petrol
    Sorry, non-vectra question
    Has anyone any experience on these engines. It is a 2000 X petrol auto. Its a colleagues car at work and has developed an odd situation.
    The spark plug holes have filled with oil which is presumably the cam cover gaskets.
    Only found the problem due to a non-start one morning. Does anyone know if engine oil is conductive, had different opinions about this and to whether the oil filled plugs were failing or something else is at fault.
    No stored codes etc, so no more clues.
    If anyone has come across this before it would be interesting on hearing about how you got along
    Mark
    Yep, common problem on that engine, soak the oil up with some kitchen roll first, then whip the cam cover off, put on new cam cover gasket and seal it, replace with new plugs, easy and cheap job.
    Felixstowe
    Thanks for the reply, it looks like both sides have the same issue and you could not even see the plug tops - so been leaking a while. Is there any advantage in buying dealer gaskets as opposed to aftermarket suppliers?
    Cheers Mark
    I would go with dealer parts, not dear and you know they will fit ok.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I seem to remember that the v6 engine has an oil cooler between the cylinder banks which is prone to leakage, so have a look at that, too.
    I still miss my Omega when I drive on a bumpy road
    Phil
    Felixstowe
    Thanks Phil, yes you are right. Checked the cooler and it seems OK. Its a nice motor the Omega but this particular one is costing my mate a fortune to run. It seems to consume parts at an alarming rate - I think he will go with a Veccy next time around and probably a smaller capacity petrol.
    Fortunately he is an experienced motor engineer and can do most stuff himself but just no experience on this particular engine.
    Thanks again
    Mark
  1. Omega/vectra b 2.2 petrol help if possible
    By Ace1981 in forum Engine & Drivetrain
    Last Post: 20th June 2012, 22:34
  2. my omega,
    By taylor in forum Non Vectra C/Signum Album
    Last Post: 21st April 2010, 15:05
  3. Omega 3
    By WeDesign in forum General Chat
    Last Post: 10th February 2009, 11:42
  4. omega
    By 06 vectra in forum Cars for sale
    Last Post: 9th September 2008, 18:28
  5. The new omega?
    By lborob17 in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 11:49
