Thread: dashboard lights?? no manual :(
    Nov 2007
    edinburh
    Default dashboard lights?? no manual :(
    howdy all.
    my father has a vectra. in o4 petrol engine and a little light/icon has started to flash up on the dash when the engine is on. it comes up where the door alerts are (tells you if the doors are open) and it looks like a little box with pointed things on top. if it looks like anything, i'd say a factory as it also looks like it has a chimney. ive attached my very shaky drawing of it.
    could anyoine tell me what is up with the car. still runs ok though.
    Jul 2006
    Mexico
    That mate I think is the sing for low coolant level...very important you check it ASAP...if the level is OK might be a fault in the level sensor. HTH
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Yup, as BlueRib... Coolant level low.
    Regular Member shan's Avatar
    I presume the factory is a radiator then. LOL.
    Well done Rob
    Jul 2006
    Mexico
    Quote Originally Posted by ghostrider View Post
    I`m not a blueRib...I`m a blue Rob :
    Quote Originally Posted by shan View Post
    Well done Rob
    Jul 2006
    Mexico
    BTW 04VECTRA....you can download a VX user manual fron the VX web page...you have to register (free) and you can acces the "library" look for the manual and download it on PDF format
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by 04vectra View Post
    howdy all.
    Your thermostat may be jammed open. Mines came on 2 weeks ago and the fluid level was low - slightly. I don't know much but a friend of mine who has had these problems on his vectra said that like most cooling systems the thermostat is not returning coolant to the reservoir and hence your car thinks it has a low coolant level.
    My car usually sits at 90C but for the past two weeks it has sat at 80-85C. But top up with a little water unless the level is very low - you will need coolant - the right one (colour) of course, check the rest of the forum for this. PS if you require coolant remember and mix it properly!!!!
    Gazza4
    On another planet
    Engine : 2.0
    Quote Originally Posted by BlueRob View Post
    Just removed my foot from my mouth! Sorry BlueRib.....
    Err BlueRob
    Well the i is next to the o, especially when i'm drunk
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    I noticed this coolant warning light on my instrument panel today myself, should i just top it up or should i take it to get checked out? As obviously there shouldnt be coolant loss. Its only an 05 and obviously still under warranty. Better to be safe?
  1. dashboard dead (no rev, speedo, lights)
    By Swatty in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 13:31
  2. Paradise by the dashboard lights....
    By Jockweiler in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 16:56
  3. Dashboard Lights
    By acedaz in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2009, 22:57
  4. dashboard lights not working - help please
    By Ian in forum General Chat
    Last Post: 9th October 2006, 16:25
  5. Blue Dashboard Lights
    By FACUP76 in forum Styling
    Last Post: 22nd February 2006, 19:59
