Results 1 to 10 of 14
Thread: chrismas diy, should i? shouldn't i?
    Regular Member kgsric's Avatar
    Northants
    Thumbs up chrismas diy, should i? shouldn't i?
    ........ ok got loads on the go at the minute getting the house finished for christmas the only thing im undecided about is the skirting boards, PROBLEM my mitre saw will not cut them as they are too large & it will cost me in the region of £100 for a mitre saw that will cut them.
    the room is 7mx4m, how much will it cost roughly to get some one reasonably good to fit them??
    is it worth buying a new saw & DIY??
    what do you's think?
    Are you talking about the mitres for when the boards turn a corner? What is it about your current saw that won't do it?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    have you got tilt and slide on your mitre saw, or is it just a manual jobbie ?????
    Midlands Mod Shop - NFFC.
    Northants
    my current saw has everything, but the largest mitre cut it can do is 120mm & the skirting board is 170mm
    What about a circular saw with a 45 degree option then? Half the price of a mitre saw and will do the job no sweat.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    have you got a jigsaw??..........cos in the old days you didn,t mitre the corners you cut out the profile and butt together.HTH
    Northants
    i thought about the circular saw route & jigsaw route, i just dont think i would be able 2 get the cuts spot on with them. forgot to mention, iv got my bathroom skirting board to do next week aswell, thanks all for the answers so far
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    i assume then that your saw does not slide? Can't you borrow a larger saw from a friend? If you were closer I'd lend you mine
    Northants
    it doesnt slide , seems evryone i know has the same sort of saw as me so cant borrow, cheers for the offer anyway
    Regular Member shan's Avatar
    Why not make a one up your self. Will take 20min of your time and free. Cut 2 bits of wood with the mitre in them and nail them to a bit wide enough for your 170mm board to sit in.
