Thread: need advice!! number plate removal?
    Oct 2007
    in my vectra!!
    confused need advice!! number plate removal?
    hi,guys ...and gals!
    i have a new reversing camera and sensors to put on the sri estate,its one that goes where the number plate is ,but i need to take the number plate off, so does anyone know how to do this without breaking the number plate, its stuck on,as there is no bolts .
    any advice apeciated.thanks shane
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    just pull it slowly m8 it shouldn't break
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    I would try and prise it gently from the centre if you can get something underneath an edge..If you try from the edges you run a greater risk of snapping it i'd have thought..
    Unless you get a hairdryer, heat the plate up, and hopefully will heat up whatever is holding it on behind it, and make it easier to remove..
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    They are normally screwed on.. Someone has obviously stuck them on, to stop them being nicked. Done that with mine.
    I suggest that you pour some warm, soapy water down the back and prise them off with a plastic ruler.
    Regular Member jonnye's Avatar
    Feb 2006
    Derby
    get kettle on lol
    pour hot water down the back and pull it off, should be held on with sticky pads
    Regular Member shan's Avatar
    If you have any fishing line or even some thread handy. wrap it around each hand and half about a 1 foot piece between your hands and put it around the plate and cut it off. It will come off real easy. You will not brake your plate like this.
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    We use a thin decorators scraper @ work
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by ghostrider View Post
    Exactly what anti theft plates are. Alledgley, once stuck on they cant be removed but as above I would try with heat & wire or just rip it off and buy a new one that you can screw on
  1. Number plate G4 ASB
    By the_wave_rider in forum Parts for sale
    Last Post: 23rd June 2009, 20:08
  2. Transfering a cherished number plate - advice
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 14:52
  3. number plate
    By viki_3.2 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 12:52
  4. Number/name Removal
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 00:02
  5. Number Plate
    By soulman in forum General Chat
    Last Post: 18th September 2006, 19:06
