Thread: F40 gearbox oil change
    sheffield
    Default F40 gearbox oil change
    Hi all,
    I'm sure I have read somewhere that the F40 gearbox on my 1.9cdti(and probably others) is sealed for life? is this so?
    coz was wondering if anyone had managed to change the oil on this box?? and indeed if it would be considered necessary to even try and do this??
    Nothing wrong with the box just something I was contemplating as I am expecting to take the car past 130k miles (84k at mo).
    pete mc
    Regular Member mushy2007's Avatar
    Liverpool
    You dont need to change the oil only check the level on routine services.
    sheffield
    interesting thought?
    How do you check the oil level if the box is sealed for life??
    pete mc
    Regular Member benny's Avatar
    Feb 2006
    dudley
    when they say sealed for life they dont mean it is actually sealed .....you can still drain an fill the box .........the oil they use is sposed to be so good it will last the life time of the gearbox or car ........i think a change wouldnt hurt the box as long as you did it right and used the correct amount of oil....
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
f40 gearbox oil change
f40 gearbox oil level
opel 1.9 cdti F40 gearbox oil level
f40 gearbox oil
