Results 1 to 10 of 16
Thread: Steering rack wear?
    north east
    Default Steering rack wear?
    2002 3.2 Elite 5-Door
    51000 miles.
    Car slightly wanders to the right on some occassions, whilst in for service, local dealer informs me that the steering rack is badly warn and needs replacement, resulting in a bill for nearly £900!!!!!!!!!
    Not happy.
    Got a second opinion, very slight play in steering rack, although nothing to worry about........
    What?
    Under the impression the first place(main dealer) were trying to get the cash from my better half.....
    Anyone else have a 'fault' like this?
    Is it a known fault?
    Do I need to worry?
    Any thoughts on this one are welcome, thanks!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    sound's to me like the first diagnosis was a bit ott, and they were out to make money.............
    if the second oppinion said nowt to worry about then there you go mate
    this is only imo though
    Midlands Mod Shop - NFFC.
    [Ex]Admin Duncan's Avatar
    If the car is wandering a bit to the right, first thing I would get looked at is the tracking. Sounds like the first dealer just wanted to stiff you for a large bill!!
    Full Member Big Sig's Avatar
    Mine did that, it ended up being the uj on the steering column
    Regular Member cpt slow's Avatar
    In a house
    I had a simillar problem , but ours also had a terrible knocking noise . Had a recon rack fitted by an independant garage , but the knock was still there . Eventually after spending a stupid amount of money it was the universal joint on the bottom of the steering column . DONT spend money on a rack without checking that 1st .
    Quote Originally Posted by caprimanuk View Post
    Yep thats what mine was
    In a house
    Fairly common problem so im lead to believe .
    north east
    Thank you all for the replies.
    Regarding the UJ on the column, any way that I can check this myself?
    Regular Member simac's Avatar
    Wirral
    Is this similar to the problem which the Vectra B had when the steering would knock because of the steering column coupling ?? I hope not, with my Vec B it was replaced three times and always came back
    Regular Member steph79's Avatar
    kilmarnock
    My cars last MOT the guy said i had slight play in the steering rack, that was January! i just had a look now as i had completely ignored it all year, when on stands there is play on the drivers side wheel bit none on the passengers? the play is side to side bout <1/4" of an inch.
    How much are steering racks, where will i get one, and how much for fitting?
  1. steering rack
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2012, 19:29
  2. Steering rack help
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 19:10
  3. steering rack
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 20:54
  4. steering rack?
    By the_wave_rider in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2009, 13:52
  5. Steering Rack
    By maxd cavy in forum Engine & Drivetrain
    Last Post: 26th June 2009, 09:21
vectra c knocking steering rack
