Thread: How do you turn off the auto light switcher
    Nov 2007
    Poland
    Default How do you turn off the auto light switcher
    Ok, the problem is - my vectra doesn't have four positions of the lights (headlights) switch - i mean [auto] [0] [1] [2] - my has only [0][1][2]
    And now - when I'm turning engine on the lights are also turning on - I don't want it to happen. Anybody knows how to do that?
    Thanks.
    Has it always done this, or only recently? If only recently, then it could indicate that the plug on the back of the switch has become loose. e.g. if you disconnect the plug you can't turn the lights on with the dial, but what happens is that the car then kicks in with a safety feature and turns on the headlights with the ignition. I'm assuming it does that so that if the headlight switch module ever goes faulty, it won't leave you without any headlights.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by freqfreq View Post
    Thanks.
    Tech2 will be needed; it looks as if yours has been programmed to do so("tagesfahrlicht" - obligatory in some countries)
    Melbourne, Australia
    Quote Originally Posted by sig63 View Post
    AKA "daytime running lamps" in English.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by stevedee3 View Post
    Thanks could't find the word
    Essex
    Duncan may have been spot on actually!
    Mine was just doing the same (lights coming on regardless of switch setting upon switching ignition on) after I removed the lower dash and had the light switches out.
    As I've only had the car a week, and it was night, I didn't know if had always done that.
    Removed the headlight switch panel again; reinserted the wiring plug, and bingo. all working again.
    Ian in Essex...
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    That's one way of doing the auto lights mod..
  1. Turn off auto radio?
    By Rab in forum Vectra C / Signum Troubleshooting
    Last Post: 26th January 2014, 19:27
  2. Insignia How do turn off auto air-con?
    By Vaux-Man-G in forum Insignia car chat
    Last Post: 22nd December 2012, 05:26
  3. turn abs light off
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2010, 18:25
  4. Service Light: How to turn off?
    By barkzz in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 19:16
  5. Qed hdmi switcher
    By tyreman in forum General items for sale
    Last Post: 18th October 2007, 16:30
cant turn off lights when car is running vectra c
what happens if I dont turn off vectra c safety okay
