Thread: heater problem
    Jun 2007
    Black Country
    Default heater problem
    Bit of a strange question this one
    My Signum has the fully automated heater set up
    ie, i can have the fans on any speed from 1-7
    or have AUTO on and let the car sort itself out with the aircon
    my question is, is it possible to choose where the heat goes??
    reason i ask is, i suffer with heat retention (not sure with the correct terminology) i burn up, even in the middle of winter my body temp can get so hot i will literally get sunburn under my clothes,
    at the moment as the weather has been a bit cold, ive had the heater on at 19 degrees which is plenty warm enough for me, but my feet are now on fire and my skin is peeling off and bleeds like crazy (not a pretty site)
    my last car had the option to direct the heat to where you wanted it, regardless of the auto feature
    if it comes to it, ill just tape the feet vents with gaffer tape
    [Ex]Admin Duncan's Avatar
    Do you have the Climate Control? If so, push the big button (the fan speed one) and you get a menu on the screen. Here you can chose all the options for where you want the air to go.
    Jun 2007
    Black Country
    Really??
    im off to check, back in 2 mins
    Jun 2007
    Black Country
    Bluddy hell, i never would have guessed that in a million years
    ive just set it to face only for now and killed the air con off aswell to save a bit of fuel
    what does the other thing do?? air quality i think it was ??
    Duncan i owe you a pint mate
    Full Member Big Sig's Avatar
    Air quality is supposed to auto switch to recirc in bad air quality areas i believe. Did you also know that if you alter the passenger temp so it sdifferent from the drivers side, you can push the drivers heat control and it will then adjust both sides at the same time!
    (do I get a free pint too )
    Quote Originally Posted by Guyver1 View Post
    Just as Big Sig said.
    lol, nice try!
    Jun 2007
    Black Country
    ahhhh but the pressing of the drivers heat control ONLY works when i swear at it while pressing it, otherwise it does nothing atall
    Feb 2006
    Dorset
    my car does lots of things when i swear at it ....
    i like my semi automatic climate control , i decide where the winds coming from and it does temp and speed ,
  1. Heater problem help
    By squeeze76 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 10:35
  2. Heater problem
    By kirstylt in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 20:16
  3. Another Heater Problem...
    By MMansfield in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2012, 22:57
  4. Heater problem, help please
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2010, 17:36
  5. heater problem
    By rickeys16v in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2010, 02:34
